Two antennas on 2011 Prius?
Discussion in 'Gen 3 Prius Audio and Electronics' started by ben12345, Jun 1, 2011.
  1. ben12345
    ben12345 Junior Member
    32
    Orlando
    Are there two antenna's in this photo. The regular AM/FM antenna (stick) and the satellite antenna (small disk that is circled).
    Is the circled item the satellite antenna or something else??
  2. macmaster05
    macmaster05 Senor Member
    4,050
    729
    its sumfing else
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    It is the nozzle for the wash spray.
  4. macmaster05
    4,050
    729
    Benvolio - the XM antenna is under the center console box and mounts under the drivers seat.
  5. ben12345
    32
    Orlando
    That clears it up. Thanks.
  6. ben12345
    32
    Orlando
    It seems to work just fine but I thought it had to be mounted on the exterior of the car (to see the satellite) that is why I assume the small item might have been the antenna (I now see it is the rear window washer).
  7. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I'm pretty sure the sat radio antenna is in the base of the radio antenna assembly (also in your pic). The sat radio ECU is under the driver's seat, but I believe the antenna needs to be on the exterior of the car.
