Two Bluetooth Cell Phones but only one Prius
Discussion in 'Gen 2 Prius Main Forum' started by havanese_boy, Sep 18, 2006.
  1. havanese_boy
    havanese_boy New Member
    Tennessee
    My wife and I have a 2005 Prius, and up until now only one cellphone that used bluetooth.
    My wife is getting a bluetooth phone this week from Verizon. So now there will be two phones.
    How will the Prius handle two cell phones with both phone's bluetooth turned on?
  2. aaf709
    3,862
    2022 Prius Prime
    As I have Verizon, I had to use a second non-Verizon BT phone to send the phonebook to the Prius. I had to change the pairing to the phone I wanted to use in order to make it work. It was easier the second time as the phone remembered what the settings were.
  3. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    <div class='quotetop'>QUOTE(havanese_boy @ Sep 18 2006, 12:26 PM) [snapback]321206[/snapback]</div>
    I think you meant when both of you are in the Prius with Bluetooth phone turned on, correct?
    The first one in the list will be connected. :)
  4. onerpm
    onerpm New Member
    477
    MN
    The Prius will connect to whichever phone it was connected to the last time you drove. In order to switch to the other phone, you will have to go into the phone menu and find the button to Select Phone, then select which phone you wish the Prius to connect with. It will look for only that phone until you switch it manually again.
    In other words, if you have the Prius connected to your phone, it will look for your phone every time you drive it. Even if your wife takes the car by herself, the Prius will not connect to her phone automatically.
  5. Jeannie
    Jeannie Proud Prius Granny
    1,414
    Central New Jersey
    <div class='quotetop'>QUOTE(havanese_boy @ Sep 18 2006, 01:26 PM) [snapback]321206[/snapback]</div>
    I'm not sure how it would handle having BOTH bluetooth phones in the car at the same time, but I have two bluetooth phones set up ( the other being my son's phone, but he lives 250 miles away).
    The 'history of calls' is shared - I don't know about the phone book, because my son didn't set one up.
    I think if ONE bluetooth phone is turned on and you both get into the car, if the 'on' phone was the last one used in the Prius, everything's fine. If it was the 'off' phone, I think the display asks if you want to use the 'on' phone after it detects it.
    I'd suggest that the 'driver' have the phone 'on' and the 'passernger' have the phone 'off' - you'd have to test, thought, to see what happens when the passenger turns the phone on and dials from the cell phone.
  6. havanese_boy
    Tennessee
    Thanks guys...basically for us, it means that when my wife drives the prius she will have to manually go in and select her phone and then ditto for me when I get the car back.
  7. onerpm
    onerpm New Member
    477
    MN
    <div class='quotetop'>QUOTE(havanese_boy @ Sep 18 2006, 01:28 PM) [snapback]321239[/snapback]</div>
    yep. i went through that for a year; then, my wife got her own prius!
    rpm
  8. havanese_boy
    Tennessee
    <div class='quotetop'>QUOTE(onerpm @ Sep 18 2006, 04:28 PM) [snapback]321263[/snapback]</div>
    Shhh...don't give her any ideas!!!
  9. tacomel
    tacomel New Member
    152
    Your understanding is correct.
    Unfortunately the following statement is FALSE: if the last "on" phone is not detected but another phone is detected, the car will ask if you want to use it.
    The truth: if the last "on" phone is not detected, the screen will say "bluetooth connection failed" and act as if there is no phone connected. To switch to the other phone you must go into the settings and click "select telephone" and then choose the correct phone. It will then pair. Note that you can do this only when the phone is stopped, because this is grayed out when the car is in motion. (I'll bet you feel safer.)
  10. wesj49
    wesj49 Junior Member
    72
    CA Central Coast
    If you want to use both phones in the Prius at the same time, forward calls from the unconnected phone to the BT connected phone.
  11. havanese_boy
    Tennessee
    <div class='quotetop'>QUOTE(wesj49 @ Sep 18 2006, 11:17 PM) [snapback]321467[/snapback]</div>
    That is a good idea...I would not have thought of that.
  12. Tadashi
    Tadashi Member
    796
    Fort Hood, TX
    <div class='quotetop'>QUOTE(havanese_boy @ Sep 18 2006, 02:03 PM) [snapback]321274[/snapback]</div>
    You can always give her your Prius out of the goodness of your own heart... then go order a 2007 :lol:
  13. Trojan
    Trojan New Member
    63
    <div class='quotetop'>QUOTE(onerpm @ Sep 18 2006, 12:28 PM) [snapback]321263[/snapback]</div>
    Yeah, that's what I'm thinking my wife and I are gonna have to do, too! :)
