Two fill holes for 2007 Prius transxale
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Nicknick, May 24, 2015.
  1. Nicknick
    Nicknick Junior Member
    Alabama
    I have read several threads about two holes to fill transaxle fluid. I know there are two but some people still think the only one to fill the fluid is the one where you actually check the level. Could someone verify that there are two fill holes?
    Nick
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    One fill/check, the second one is the drain.
  3. northwichita
    481
    102
    29
    Wichita KS
    The top fill plug appears to be underneath the inverter, so its much more practical to use the check plug to add fluid--Hobbit write up a good description , read about half way down this web page.
    Spring maintenance
