Two questions about coolant change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Taxi/Limo, Mar 16, 2023.
  1. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    I was able to successfully change my radiator coolant inverter is next
    Here are my questions
    Car car nut on youtube said the fan has to come on twice while in maintenance mode after you fill the reservoir
    Do I need to do that with the radiator coolant change? I did not have the time
    (I did fill the coolant reservoir let it drain down and then toped it off it took a little over a gallon?)
    Next question
    Where can I get the proper hex tool to drain the inverter coolant system?
    Thanks
  2. Mendel Leisk
    40,583
    Regarding #1: you’re probably fine. I let mine run about 1/2 hour, then gave up, fan never turned on.
    regarding #2: you can buy hex socket sets, 3/8” or 1/2” drive; they’re a common mechanic tool.
  3. Taxi/Limo
    524
    107
    Okay Thanks
    Is it more crucial to have the fans go on twice in maintenance mode when doing the inverter coolant change?
  4. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    It fits an ordinary hex key (commonly called "Allen") wrench of appropriate size.
    Taxi/Limo likes this.
  5. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    The point of having the fans "come on twice" during the ICE system checkout is to have the engine run long enough that presumably the thermostat is opened and purged any air.
    The fan comes on once- the engine is hot. The fan goes off- the temperature has gone down some (ie the cooling system is actually working). The fan comes on again- temperature control should be stabilized.
    Early on in the process, I monitor ECT on my scantool, and as it goes up, I check for warm air from the heater.
    For the inverter system, the only real concern is verifying good coolant circulation and purging any air. That's not directly tied to how long the ICE runs.
  6. Taxi/Limo
    524
    107
    Why do you monitor the engine coolant temp using your scantool during ICE system checkout? I am assuming ICE mean internal combustion engine
  7. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    That's just one way to make sure the coolant is hot enough for the thermostat to open, allowing coolant to circulate through the radiator. That should help push any air pockets out. Same is true of waiting for fans to come on.
    #7 CR94, Mar 17, 2023
  8. ChapmanF
    17,345
    The key is to warm up the engine well enough that the thermostat fully opens, and then run it several minutes longer, while shaking and squeezing some hoses to dislodge more air.
    Before the thermostat opens, there are parts of the system where coolant isn't circulating, so the last of the air isn't effectively removed until after it opens.
    If the weather is cool, it can take quite a long time for the engine to warm up enough that the thermostat opens. It can feel like forever if you haven't got something to watch. If you have a scan tool showing the coolant temperature rising, and you know what temperature the thermostat opens, then at least you have something to watch and you have a better idea how long you will be waiting, and it doesn't just feel like forever.
  9. Mendel Leisk
    40,583
    Something you can put on a ratchet wrench will be more stable and with a longish handle much easier to break it loose, and less prone to round the hole.
    torque spec in one of the attached:
  10. Taxi/Limo
    524
    107
    What temp do you look for?
  11. Grit
    Grit Senior Member
    6,454
    4,188
    Wilkes Land
    I’ve seen oil change people put the oil pan screw back on and begin tightening while engine oil was still draining when there was a long line of cars waiting for oil change.
