Two questions about HV battery pack
Discussion in 'Gen 3 Prius Technical Discussion' started by PRI6080, Jul 21, 2022.
  1. PRI6080
    PRI6080 Junior Member
    22
    Tried searching but could not find if someone has posted a writeup on removing the battery pack out of a 3rd gen (2010) Prius IV.
    Also, I've seen conflicting information about what side(drivers side or passenger side) is the number one block. Dr. Prius app is telling me block number 13 is bad and I want to make sure which one it is in the whole pack.
    Thank you.
  2. AzusaPrius
    AzusaPrius Senior Member
    1,878
    823
    Passenger side.
    Have someone to help remove it to save your back.
    PRI6080 likes this.
  3. PRI6080
    22
    So if Dr. Prius indicates number 13 block is bad, that'd be one of the last few blocks on the driver's side?
  4. AzusaPrius
    1,878
    823
    Yes
    PRI6080 likes this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,918
    Columbia, SC
    Regardless of battery model, block 1/module1 is always where the large orange main cable is connected to the negative terminal.
    PRI6080 likes this.
  6. ASRDogman
    ASRDogman Senior Member
    6,092
    3,273
    Have you searched youtube? I found several videos of removing the hybrid battery.
    How are you going to balance the pack after replacing bad packs?
  7. PRI6080
    22
    There is only one bad block. Still working on /looking for how to balance whole pack.
  8. bisco
    49,500
    there are lots of threads here, but not one we can refer you to. you just have to start digging.
  9. PRI6080
    22
    In this video, the guy says block number 1 is on the passenger side. You say it's on the side where the orange cable is like at the 50sec mark in this video, which is shown here in the driver's side.
    Is there another orange cable connection the passenger side I'm not seeing here?
  10. ChapmanF
    15,630
    At each end of the pack, there is a module with a big orange cable attached to it. At one end, the cable is attached to the module's + terminal. At the other end, the other cable is attached to that module's − terminal.
    TMR was talking about the end where the cable attaches to the − terminal.
    PRI6080 likes this.
  11. ASRDogman
    6,092
    3,273
    Must be a Gen 2. Looks a lot different than my 2010....
    Just throw that stuff around, doesn't matter where it lands....
    Those buss bars looked bad. But it doesn't matter. Why clean them while you have it apart???
    Should have started the car before puttting it all back together.
    No need to balance the pack... the car will do it. Why did Prolong spend all the money and time
    in research to come up with their system???
    If those cells were back, shortly others will follow....
  12. PRI6080
    22
    Thank you for clarifying that. I'll probably be tackling this tomorrow, finally.
