two spaces between sentences
Discussion in 'PriusChat Website Questions' started by theorist, Aug 1, 2006.
  1. theorist
    theorist Member
    365
    Lexington, MA
    I miss the ability to put two spaces rather than just one between sentences. Sure I can put them in in when writing my post, but they are displayed as a single space when posted.
    Can an adjustment me made to the software settings? Is there a simple html code or bbcode that I can use within my postings?
  2. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    Currently, the board will remove double spaces. I'm not sure why but it does.
    If you need to use spacing for things such as charts, I've seen people use the (CODE) command like this:
    Code:
            Column 1        Column 2
    Row 1     value          value
    Row 2     value          value
    The text is monospaced allowing you to perfectly allign what you need.
    I hope that helps a little even though it doesn't add that extra space between sentences.
  3. xlarimer
    xlarimer New Member
    135
    berkeley, california
    <div class='quotetop'>QUOTE(theorist @ Aug 1 2006, 05:55 AM) [snapback]295631[/snapback]</div>
    Yes, I too miss the double space between sentences as I was taught in typing school. (Ahhh, IBM Selectrics had just started getting common but they had to be warmed up!) My hand still naturally does the double tap. But then when I was younger, I always thought that adults that don't listen to what the world is (and *I* am) saying are closed minded. So when I realized that the world has changed this and it is now taught one space between sentences in schools, I've started to change my view and typing style. It is more efficient to only tap once (after trying to get used to it,) it can still understood by anyone who can read what the end of the sentence and the beginning of another is, and lastly it is part of the ever changing standard. However, I still like to follow the capitalization rules.(!) I have many friends that have started writing to me without any regard to using capital letters at the beginning of a sentence.
    This is similar to the change over from the 10-2 steering wheel position that I was trained to do in driving school to the newly trained four and eight position. (And the reason why the spoke of the Prius' buttons are perfectly suited to it.) It is for safer use of the airbag in an accident so we don't get as hurt. It is still hard for me to go to that driving position, but at least I'm trying.
    This old dog is at least trying to learn new tricks
  4. brandon
    brandon Member
    771
    Manhattan, KS
    I think the reason it removes the second space character is primarily a function of HTML. In HTML (hypertext markup language) duplicate spaces are always ignored; i.e. "Hello(SPACE)(SPACE)World" becomes "Hello(SPACE)World." We probably can't blame the board software for this one.
    If you want to enter a second consecutive space using HTML, you would use the non-breaking space character, but this is not easily reproduced in this forum (the "edit" function actually populates the the form with a (SPACE) instead of the code for a (SPACE)).
    The non-breaking space character:
    Code:
  5. BlairMartin
    BlairMartin New Member
    <div class='quotetop'>QUOTE(theorist @ Aug 1 2006, 08:55 AM) [snapback]295631[/snapback]</div>
    "Two spaces between sentences" is a carry-over from the old typwriter days, when every letter was given the same amount of space, and all were wide by today's standards. Nowadays, people are used to reading text that has narrower fonts (more characters per inch), is proportionally spaced ("M" gets more space than "I"), and more tightly set (less space between letters).
    In this environment, it's commonly believed that having a wide space after a period is unnecessary. (I don't know about you, but my right thumb always wants to make two spaces anyway!)
    Blair
  6. Godiva
    Godiva AmeriKan Citizen
    10,339
    The fonts used in wordprocessing are different than those used by typewriters. The additional space isn't needed. I forget where I read the justification for this, but I broke myself of the doublespace habit long ago when I got my first computer (1986).
    Time to let go and give the thumb a rest. (BTW I learned on a manual Royal typewriter. Still have my electric Smith Corona...never could afford even a used IBM selectric.)
