Two Year Results
Discussion in 'Gen 2 Prius Main Forum' started by jkash, Feb 25, 2006.
  1. jkash
    jkash Member
    889
    West Hills, CA
    I will have had my car two years tomorrow. I filled up with gas today, and here are the two year results.
    22,745 miles driven
    53.3 mpg Lifetime display
    52.2 mpg Lifetime calculated
    379 miles per tank
    7.26 gallons per tank
    $2.32 per gallon average
    435.746 gallons of gas = $1011
    My old car was a Honda Civic VX @ 40 mpg = 325 gallons for 13,000 miles = $754.00
    (We always took my wife’s Acura CL for longer trips)
    Acura CL @ 23 mpg = 423 gallons for 9745 miles = $983
    Savings = $726 in two years. It doesn’t sound like much, but it is better than nothing.
    I have had only one problem with the Prius. I had to have the MFD replaced. Other than that, the car has been perfect. If I could change anything, it would be nice to be able to get more gas in the tank, but that has been beaten to death here. I usually fill up with one or two bars left. I have only seen the last bar blink twice. I'm sure I could go further than I do, but I don't think it is worth the risk.
    I love the car today as much as the first day of ownership. PriusChat has also added greatly to that enjoyment. I look forward to many more years of both.
  2. glenk
    glenk Member
    109
    Fairfield, CA
    That's a great lifetime for that many miles. I woud think it takes a lot of discipline to achieve that.
    What type of driving, mainly freeway? At what average speed?
  3. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Sounds about like mine. Just passed 2 years this week.
    30600 miles driven
    56.1 mpg Lifetime display
    54.4 mpg Lifetime calculated
    407 miles per tank
    7.52 gallons per tank
    $2.109 per gallon average
    562.384 gallons of gas = $1186
    Though it seems that in addition to the SSCs and recalls, I've had more stuff replaced than you.
    Replaced so far:
    Center Console Cover (coming loose)
    MFD (died)
    Headliner (sagging)
    Tail Lights (melting)
    Door Sill Trim (warping)
    and, last week, the HV Battery, as detailed in the other thread.
    Still love the car in spite of the teething pains :)
  4. MNPrius
    MNPrius New Member
    177
    Minneapolis
    I'm impressed not only with the MPG but the relatively few miles driven. I'm a four month owner and I'm at the 7000 mile mark. That means I'll be close to your mileage in 1 year, not 2. Thanks for sharing your stats!
  5. jkash
    jkash Member
    889
    West Hills, CA
    I drive 12 miles to work and then back again on city streets. I do that 6 days a week during the school year, and than five during summer school. It takes me 25 minutes to get to school, and about 35 minutes to get home. That is about half the miles I put on the car. The rest is just around town, usually on the freeway.
  6. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    Two years in August. Will let you know but so far so good! Will follow your example.
  7. Springtime
    Springtime Member
    158
    Eastern PA
    OK, without hunting through the manual to find the answer, how do I pull up the lifetime display of mpg?
    Springtime
  8. jkash
    jkash Member
    889
    West Hills, CA
    You can't pull up the lifetime average. You have to keep track of it. Those of us motivated or obsessed enough keep an Excel spread sheet with our fill-ups on it.
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    wow the gap between the MFD mileage and your calculated mileage seems to be a bit large.
  10. Oxo
    Oxo New Member
    533
    Oxfordshire, UK
    Yes, but there seems to be a gap for everyone. Can anybody explain why? Surely it's not because Toyota is trying to mislead us? If not, why have they not put a correction into the software?
    Or could it be because the gallon you buy is not an accurate gallon? Maybe the retailers tend to build a small error into the pump measurement so that you get say 2% less than you think you're getting. I was told once that this would be within the law because an error of +/- 5% would be acceptable in law.
  11. notsure
    notsure New Member
    236
    PHOENIX AZ
    I am averaging 51.2 mpg, without any real effort to save gas, cool in am 38-45 warm in evening 60-80. Almost all freeway driving 65-75 mph.
    Still in break in period, 1100 miles.
  12. xraynano
    xraynano New Member
    56
    Chicagoland
    I am still in break-in (just over 1000 now), but I am averaging 40.3 mpg. Mostly round trip to work (3 local, 12 hwy, 2 local). But it starts out cold in the mornings (25-35F) and under 45F every afternoon. First few miles always 25mpg, usually 50mpg at the end. Hopefully, this will significantly improve when warmer weather returns.
  13. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    for everyone?? you might want to recheck that. there have been several posts verifying that over time, the two numbers merge so much so that many stopped tracking the pump figures. mine are much less than a ¼ mpg apart.
    i do not recommend that (stopping the 3 P method; pump, paper, pen) as i used pump calculations to file a report on a pump that i suspected was shortchanging me. it was later reveled (almost a year later!!) that the pump was inaccurate but not enough to "warrant further action" after its "normally" (state law mandates every three years, it was a month short of 5 years when if finally got done) scheduled calibration.
    there was also a special on the local news when an independent company went out with measuring equipment to several different gas stations. they got 5 gallons from each, all with digital pumps accurate to 1/1000ths of a gallon. meausred the volume received and found that 11% were inaccurate beyond allowable limits with 3/4 in the favor of the gas station. due to this study, they estimated that Washingtonians were paying more than $150,000 a month for gas they did not receive.
    because of the way new pumps work, its nearly impossible for stations to purposefully cheat you, however there is a metering valve that does become inaccurate due to normal wear and tear which is the reason that the 3 year time limit on inspections is on the books. but in the state of WA, there is only 9 inspectors. they are way behind and average inspection time runs 4½ to 5 years between stations unless they receive multiple complaints about the same station. the station i filed a complaint against (the arco just off the courthouse exit on hiway 101) is one of the busiest, largest and cheapest in the area, centrally located between two small colleges and the associated cheaper (and crummier) than normal mostly student housing.
    also the acceptable error for the state of WA is something like +/- .002 gallons...iow...practically no error allowed.
    soooo, you are probably right, you are being shortchanged....stats show 1 in 13 are.
  14. john1701a
    john1701a Prius Guru
    12,760
    5,246
    57
    Since two other Toyota vehicles had that same problem, neither of which were a hybrid, it doesn't count as something related to Prius.
    It's also helpful to point out that replacement cost was zero, covered under a TSB.
  15. john1701a
    12,760
    5,246
    57
    Compared to what?
    The Classic had a variance of 2.0 MPG based on my 59,827 miles of data. For my HSD as of 48,820, the variance is 1.4 MPG.
    Jeff's reported 1.1 MPG is pretty close, not bad at all considering the computer is estimating & rounding.
  16. Oxo
    Oxo New Member
    533
    Oxfordshire, UK
    I said "seems that everyone" because that was the impression I had from reading PC comments. I suppose the majority of us haven't done a careful check. I've not been able to check mine yet because I haven't done enough miles to get a reliable result but it's a relief to know that the car's estimate may well be accurate.
    If 1/13 are being shortchanged, how many are getting more than they pay for because of pump inaccuracies? Or are defects in pumps always in favour of the seller?
    Anyway this is all fairly trivial because a 1% error in favour of the seller will cost you about 20 cents each time you fill up so in a year's motoring of say 10,000 miles, somewhere around $6 a year? Maybe the retailers deserve that!
  17. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    actually, 1 in 13 are being shortchanged. out of the fillups, 11% were inaccurate with 3/4th of those readings being in favor of the station. now this is a random sampling of around 100 station pumps of the thousands in the state.
    either way, i think you can consider the MFD very accurate.
  18. jeneric
    jeneric New Member
    442
    Redmond, WA
    What do you mean by "estimating?"
  19. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    You forgot the nearly two tons of emissions you didn't put out.
    You also forgot to mention the hard-to-evaluate "advertising" you've given the cause of environmentalism simply by driving a car everyone recognizes as a hybrid.
    Bob
  20. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i still think the best part of my Prius is the calmness i feel because the car does not idle while sitting in traffic. not having that constant vibration (cant hear it since stereo of one type or another almost always on) is calming in a way i can not explain.
