u shaped pcv out hose 3/8 id but size into air?
Discussion in 'Gen 3 Prius Main Forum' started by thewirm, Apr 10, 2023.
  1. thewirm
    thewirm New Member
    wis
    Just so i have it right.
    The pcv out hose is 3/8 ID ,but this u shaped hose connects to air intake with a (5/8 id?) hose connection.
    Thus making a catch can out hose to this a 5/8 fitting ,5/8 hose from catch can.
    thanks
  2. Mendel Leisk
    38,664
    A lot of people just cut that hose at middle, leave the ends connected (at PCV valve and intake manifold), and push 3/8 barb splices at cut ends for connection to 3/8” ID fuel lines to OCC. more info in first link in my signature (link to mother of all OCC threads). If you’re on a phone turn it landscape to see signatures.
    replacement PCV hose is cheap and readily available from dealership, if you need to restore to stock.
    my setup attached:
