U0100 U0293 Intermittent
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dogjames, Jan 23, 2017.
  1. dogjames
    dogjames Junior Member
    Orlando, FL
    Hi all, my 2004 Prius is having some intermittent issues. What happens is I will be driving along and I will get the /!\ CEL, ABS and TRC light and the ICE will start runing, I have had this issues intermittently since Oct. before simply restarting the car would resolve the issue. Now it works only when it wants to, I have had some luck moving the wires that go into the fuse box as a tempoary fix and the issues seems to be caused by bumps in the road so my money is on something is lose are being shorted. The DTC codes are always either u0100 or u0293 or both. I have a mini VCI on the way. I have already replaced the 12v and have tested it.
    52,402
    welcome!
    is the battery negative to ground clean and tight?
  3. dogjames
    Orlando, FL
    That appears to have been the issue, thanks!
    52,402
    pleasure.
  5. rick nepra
    rick nepra Junior Member
    long island
    i have 2010 gen3 I just put a engine out of a wreck that had 150miles on it. after swap now dash says check hybrid system and I have a U0100 code. car gets ready but doesn't start gas engine.
    Sulle and HDpwrsvr like this.
  6. HDpwrsvr
    HDpwrsvr Junior Member
    Technology
    I know its been some time, but did you ever fogure out wat caused the u0100 code? I have an 2009 and having same issue. Titled 2009 prius ICE not starting. Thank you
  7. rick nepra
    long island
  8. Sulle
    Sulle Junior Member
    London
    ----UK----
    Hi
    Did you find any solution of Prius 2010
    With code u0100 ??
    Please let me know
