Uber driver with a few questions
Discussion in 'Gen 4 Prius Main Forum' started by roadwarrior28, Jul 7, 2016.
  1. roadwarrior28
    roadwarrior28 Member
    68
    69
    Portland, OR
    Three Touring
    Hey guys. Like I said, I'm a rideshare driver who drives about 1000 miles/week. I currently have a Gen 2 which I love, but I'm looking to upgrade to a Gen 4 pretty soon. I have some questions I haven't been able to find answers for looking on the forums yet:
    -Does the Gen 4 have the same kind of under-trunk storage area in the hatch/cargo area? This is important for me on the Gen 2 because it allows me to carry equipment while having an empty hatch space for passengers luggage. Does it depend on if you have a spare tire or not?
    -Has anyone observed real-world MPG in extended city driving with A/C on?
    -Where are the 12v outlets? And has anyone been able to extend one into the hatch area?
    -Is there a notable difference in comfort for touring vs non touring models?
    -Does the driver's seat with lumbar support make a significant difference in comfort?
    -Has anyone tried the Clazzio seat covers?
    -Has anyone done a wrap or plastidip?
    Thanks guys!
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    There will be about 2 inches more rubber tire in the non touring models, that in the touring models, is aluminum wheel. (15 versus 17 inch wheels, but same total diameter) So non touring will be more comfortable.
  3. JC91006
    16,827
    8,600
    I would use the cheapest most economical car if I were an uber driver....Just in case people scratch it or puke in it
  4. wjtracy
    wjtracy Senior Member
    11,371
    3,608
    Northern VA (NoVA)
    No the previous false floor and under-floor compartment of Gen2/Gen3 hatch area is no longer present in Gen4. The only thing you might try I suppose is to remove the spare tire - in those Gen4 models - and use that cubby space. Or get the Gen4 version without the spare tire and just get more total space. Or get the Gen3 which may be the biggest overall cargo space with 3-ft3 underneath. Some folks have been carving out the foam floor in the Gen4 back (to make space for a spare tire) but in you case you could do it to add space.
    If you want my "real not EPA" cargo space estimate numbers for Gen2 to Gen4 let me know.
    #4 wjtracy, Jul 7, 2016
  5. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Welcome, roadwarrior 28. I believe there is one 12v outlet on the dash and the other is on the back of the center armrest.
    I would expect fuel economy to be marginally better but it is a moot point as the only way to get better fuel economy than a Prius is to buy something with a plug.
    Stay with a non-Touring car with 15 inch wheels for the best FE. What are you averaging now?
  6. krmcg
    2,592
    2,392
    Whittier, CA
    I moved from a 2008 Touring Prius (16" wheels) to a Gen 4 Prius Four and my mileage improved 30%
    KimPrius3 likes this.
  7. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    If I were you, I would compare the gen 3 and the gen 4. In the gen 4 rear seats are lower in order to barely maintain head room and leg room is a bit less. Passengers will have to stoop a bit more to get into the gen 4. And the gen 3 has the under floor storage. Sit in both to compare what your passengers will experience. A 2, 3 or 4 year old gen 3 will serve you very well for a lot less money. I believe that some dealers still have some new gen 3s at big discounts. The improved mileage of the gen 4 would never make up for the difference in price.
    Of course, it is understandable if you want the latest (including safety features) since you will be driving it a lot.
  8. JohnF
    JohnF Active Member
    497
    428
    Essex, CT
    If you want an educated comparison, based on 5 years in a Gen 3 and 4 months in a Gen 4, I would take the Gen 4 every time.
    eric1234 and KimPrius3 like this.
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    If I was going to be a taxi driver (of whatever flavor) the Prius v station wagon would be on my short list.
    JohnF likes this.
  10. royrose
    1,389
    953
    Foot of Pikes Peak
    agreed. I was tempted to throw that in. I recently returned from Zurich. Most of the taxis at the airport were Prius Vs.
    JohnF likes this.
  11. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    There are 2 on the Australian ones, though we seem to have been given an odd mix of features - at the front and back of the centre console. None in the boot. (see picture attached - my fingers aren't censoring anything - just the book wouldn't stay flat).
    They're not really good - only work on POWER or Accessory modes - which turns off my GPS or phone charger when I power down for 2 minutes to go into a store etc!!!
  12. JimN
    7,028
    1,117
    South Jersey
    That's the same set up as the USA. For a quick dash in to the store I just lock the car, CC & lights off. I would miss the one on the dash as I have cables draped around the cockpit as it is.
    alanclarkeau likes this.
  13. Tideland Prius
    16,621
    1. Nope. That is gone. There is either a spare tire and a touch more space or a tire repair kit and a lot more cargo space. Two Eco, Four and Four Touring have a tire repair kit for a larger cargo area.
    2. Can't comment objectively but subjectively, expect about 50 mpg (depending on terrain)
    3. One 12V outlet is between the front cupholders and the centre console. The other 12V outlet is mounted near the floor at the rear of the centre console (intended for rear passengers)
    4. Depends how sensitive you are to changes in ride comfort. The Touring models will have a stiffer sidewall due to the lower profile tires. They'll also have a "touring spec" suspension setup so both features will result in a slightly stiffer ride
    5. I like the adjustable lumbar support on my Gen 3. The front seats on the Gen 4 are pretty comfortable to begin
    Given the mileage you put on it, You may want to consider the Two Eco. The tires run at a higher pressure (and of course if you replace those tires when they're worn, ensure you replace them with similar tires that can run the higher pressures to maintain fuel economy), they're rated at a higher mpg (58 city, 53 hwy, 56 combined) and it only costs an extra $500 (granted you lose the spare tire and the rear wiper but you gain auto headlights and 3-dr SKS.
  14. CR94
    CR94 Senior Member
    2,751
    1,205
    Northwestern S.C.
    I understood the real reason those models have no spare is to cut weight so they can squeeze into the EPA weight classes Toyota wants them to be in. That, and cost saving.
  15. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    My guess is 90% of the cabs in NYC are Prius. Most now are Prius V. There are some hybrid Camry's. And a small group of a new small van type cab's. There was a time in the past when the cabs could be any condition. With NYC pot holes you would see cabs broken down everywhere. Many with front end wheels folded over. With Prius's on the road for the last 10 years I never see them broken down.
    I wonder how many miles they run these cabs.
  16. eric1234
    eric1234 Active Member
    392
    201
    Hamden, CT
    If you go on eBay autos, you can find gen IIIs with 300k-400k for sale (cheap, of course)
  17. JimN
    7,028
    1,117
    South Jersey
    Nissan's NV200 won the taxi contract. They were supposed to be EV but that is another story. The Gen2 & Gen3 Prius as a taxi is at the end of its career as age and mileage are against them. Vehicle inspections get tougher to pass as the vehicle ages.
  18. Gen 2 Tom
    333
    286
    Lincoln Park NJ
    Yes I did see a few of the Nissan cabs. And it did seam like cabs had to be the NV200. Although there are cabs from all manufactures. Most are Toyota h
  19. bisco
    52,393
    check out ringomoon's thread. he just bought a gen 4 taxi in the u/k.
  20. Tideland Prius
    16,621
