UK 2007 Crack on Screen
Discussion in 'Gen 2 Prius Technical Discussion' started by wedmonds, Aug 3, 2010.
  1. wedmonds
    wedmonds New Member
    London UK
    Hi People,
    London U.K calling, I have a Prius 2007 T3 that I would like to replace the screen on.
    The screen itself work and displays everything Ok but the touch screen side of it is knackered due to the previous plumb of an owner sticking a sat nav sucker on the front of it. Its controllable via the steering wheel but wondered what the options are for replacing the screen.
    Toyota dealer said £2,800!
    surely the whole unit does not need to be replaced for a crack?
    Thanks all!
  2. Mike Dimmick
    Mike Dimmick Active Member
    963
    247
    Reading, UK
    I assumed you meant the windscreen initially, but you're clearly talking about the multi-function display.
    The problem is that resistive touchscreens rely on two very thin sheets of translucent, but conductive, plastic that are very close to but not actually touching. Stick a suction cup on it and it'll pull them apart and break the very delicate conductors. The conductors have to be very closely aligned and they're not readily serviceable. It's likely that the whole screen display component would have to be replaced.
    As far as Toyota are concerned, the entire multi-function display - including most of the control circuit boards - is a non-serviceable unit, which is why the dealer wants £2,800. For comparison a US discounted parts-only price is $3,400, excluding taxes.
    You may be able to find a working unit from a crashed car at a breaker. Tell them the age and model of your car - I believe the T4 and T Spirit of this age have a different resolution screen and I don't think the units are necessarily compatible. I think all cars prior to the December 2005 model change had the lower-res screen. If the V-shaped bar in the grille has chrome-effect coating it's after the model change, older cars had a body-coloured bar here. The older cars also had smoked lenses for the brake lights while the later cars have clear ones.
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I believe someone on the UK Prius site has posted a number of links above your enquiry, including a few relevant ebay items.
  4. jelloslug
    jelloslug It buffed right out!
    813
    Greenville, SC
    If you are handly with a screwdriver you can buy an MFD from any Prius (make sure you get a high resolution unit from 06-09) and just swap over the screen itself.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Don't mean to be unhelpful but in my experience as an North American, once something becomes "knackered" due to the "previous plumb of an owner" you might as well throw the whole thing in the dust bin.
    Nice to know that high cost of dealership repair extends world wide. Hope you can use some of the suggestions here, and become Unknackered.
  6. jim00seven
    jim00seven Junior Member
    SD, CA
    Jelloslug,
    Do you know of any DIY directions for just replacing the LCD screen itself instead of the whole unit? I have the same "suction cupped" LCD problem.
    Thanks, Jim7
  7. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Not Jelloslug, but I repaired my MFD a couple of months ago (cracked solder joint not LCD screen) myself using instructions available on the net. The removal instructions as well as a replacement MFD are available at:
    Plug In Hybrid Electric Vehicle PHEV (email Steve to see if shipping "over the pond" is a problem)
    You can get just the screen half of the MFD if that saves money and swap it for that section of the MFD and the disassembly instructions are at:
    Prius MFD (also has links to alternate removal instructions)
    Which are what I used to repair my MFD.
    Good luck.
    JeffD
