UK / Europe Prius 2 Coolant Change
Discussion in 'Gen 2 Prius Technical Discussion' started by Lee Tomlinson, Aug 10, 2024 at 11:33 AM.
Tags:
  1. Lee Tomlinson
    Lee Tomlinson New Member
    Today
    London, England
    ----UK----
    Does anyone have instructions for changing the coolant for the petrol engine and inverter, for a UK car?
    I can find lots of videos/instructions for US cars, but none for UK.
    There is no tank Infront of the front wheel to drain the engine coolant. Also, there seems to only be 1 bleed valve (to the right of the radiator as you look into the bonnet).
    Thanks
    Lee
    PriusCamper likes this.
  2. Mendel Leisk
    38,804
    ^That's a very nice document, likely more complete/clear than Toyota's Repair Manual. Anyway, just for a cross-check, I've attached repair manual excerpts (added the inverter instruction, just in case).
  3. Tombukt2
    Tombukt2 Senior Member
    9,385
    1,640
    Durham NC
    It sounds like you don't have the coolant heat storage tank in the UK. But you should have a drain on the radiator part of the system not the upper inverter cooling radiator but the lower engine ice radiator push comes to shove just undo the bottom hose coming out the bottom of the radiator assembly that'll drain it pretty much by gravity as it's the lowest point in the system if you're doing all this coolant changing you might be changing a few hoses and then when you put them all back together just take your time and fill it slowly that's about all you can do with the generation two unless you have one of these vacuum filling devices that speeds the process up but reality about it is pouring it in slowly doesn't really take that long you want to put in the recommended volume and that's about it
