UK Tyre question..
Discussion in 'Gen 2 Prius Main Forum' started by ikklesmiler, Oct 8, 2009.
  1. ikklesmiler
    ikklesmiler New Member
    49
    Kent UK
    Hi
    I have just bought a 53plate (2004 model) Prius.
    I went to a local tyre fitter today and asked him to price up michelin energy saver tyres for my prius, he came and had a look at her to get the size etc... he then said that i shouldnt put michelin energy saver tyres on her, If I want a good quality tyre I should use Bridgestone Tyres....
    I dont mind bridgestone tyres, they are a very good make, BUT everyone on here seems to use the Michelin energy saver tyres or hydroedges (which you cannot get in the UK) So im wondering what Tyres UK Prius owners use...
    I would really appreciate replies... :rolleyes::rolleyes:
    Ann Marie ;)
  2. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    I'm assuming that you have a very early hatchback version, not a late-model saloon. If you do have the first-generation car then my advice doesn't apply quite so much.
    The stock tyre is Bridgestone Turanza ER30 but I think it's a terrible fit for the Prius. My feeling is that the tyre is designed to run quite hot - it's described as a summer tyre and is standard fit on Mercedes and BMW cars - and that the Prius suspension geometry doesn't work the tyre enough for it to heat up. As a result it doesn't grip very well. It is not a low-rolling-resistance tyre.
    The mechanic is probably just trying to upsell you. Resist. If you want the Michelins, and they're available in the right size (195/55 R16), buy them. The load rating should be at least 87, and the speed rating at least T (118mph - the car can do about 110) though H (130mph) might be better to give some extra safety margin.
    I've heard of some people switching over to Nokian WRG2 tyres, which are an all-season tyre that should work better in the colder UK temperatures. I can tell you that the Bridgestones were not fun at all in the snow we had last winter. I'm not sure where they found the Nokians, though.
    It's very hard to give tyre advice because the geometry of different cars is so different, working the tyres differently; tyres of the same name can perform differently across the range of sizes and load and speed ratings; and actual scientific testing seems so thin on the ground. Frankly I wouldn't trust any kind of user review site, because the response is so subjective - and self-selective. In the end the makers are banking on their brand.
  3. uart
    uart Senior Member
    4,220
    1,211
    Australia
    High ikkles. If it's low rolling resistance that you're after then the "Bridgestone Ecopia EP100" measured very well in the lastest tirerack tests.
    When Round and Black Becomes Lean and Green
    You might want to check if they're readily available locally.
