Uknown vibration when battery unloaded
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ToyotaCoyotta, Apr 16, 2025.
  1. ToyotaCoyotta
    ToyotaCoyotta New Member
    26
    Lithuania
    Toyota prius 2009 gen 3, current odometer reading: 135000 km
    I recently bought this car from netherlands, it was after a small accident, where I only needed to replace body parts and left headlight, + some wires from bumper,
    This car was 131000 km odometer, maintained in an official Toyota dealer service, all history and stamps are present on the book + there are official document with odometer fixations proving that the mileage is real
    After fixing the body parts I went for a technical inspection it passed without any issues at all, even the people that work there gave comments that its really nice and technically correct car
    However, whenever I drive somewhere slow or in traffic and the battery unloads (it drops to 2/8 bars) the engine starts to vibrate intensively, it's really an unusual vibration i feel , after the battery is charged a bit, the vibration becomes lower, same thing happens when I just arrived somewhere and I press P without shutting down the car, so the battery eventually goes to 2 bars and the motor starts to charge it, however it doesn't ALWAYS happen, but a lot of the time, but it never happens when the battery has 3 or more bars,
    I was very concerned and I don't want to ignore such vibration so it doesn't cause any further damage so I took the car to service for inspection, i thought maybe the engine mount after the minor crash was damaged or some part moved out of place, but they inspected and found nothing so they told me to come back when the issue becomes bigger, however I have doubts that they felt this particular vibration, because as I said it doesn't always happen., sometimes when I want to show it to my friends its not there, however there was times when it was there and they agreed that its a little too much.
    Thank you for your help
  2. MAX2
    MAX2 Senior Member
    1,436
    481
    101
    Third planet from the Sun
    It is necessary to take readings with a diagnostic scanner and determine if there are errors or parameters that are approaching critical values. Preventive measures: checking spark plugs, coils, fluid levels, EGR status...
    51,008
    if this is your first prius, it may be normal depending on engine rpm and temp.
  4. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,455
    SacTown, Ca
    has the automatic transmission fluid ever been changed on it?
    It was hit on the same side as the transmission. Should probably makes sure there's nothing bent or out of place in that corner and retorque all the bolts near there.
  5. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    Yes, unless the engine is misfiring.
    When it starts charging the battery while parked, the engine is running under load, at (I think) roughly the same speed it runs initially after a cold start.
  6. wukong sun
    wukong sun Junior Member
    65
    I also have similar problem
    When the high-voltage battery needs to be charged, the engine begins to vibrate as if it is missing a cylinder.
    Return to normal after charging is completed
    When it shakes, it will stop shaking immediately if you step on the brakes.
    I thought it was a vacuum leak, but I checked and said it wasn't vacuum-assisted brakes.
    any progress
    Remember to come back and communicate
