"Ultra-Fast Warmup Switch" idea
Discussion in 'Generation 1 Prius Discussion' started by Tryyn, Dec 10, 2021.
  1. Tryyn
    Tryyn Junior Member
    37
    Madison, WI
    2002 Prius
    During our 02's recent incident of no heat, I noticed that the Stage 4 (idle stop/EV) threshold was reached about 2-3 minutes after startup. After coolant was added, going back to normal warmup times (5+ minutes) was frustrating.
    Would there be some way to reduce engine cooling, get to operating temp ASAP, and then allow coolant flow so I have heat? I'm imagining a solenoid valve hooked up to a button marked "WARMUP ASSIST" or "WARMUP."
    I was also thinking about a secondary air induction hose running near the hot exhaust manifold, with an electric valve hooked to a similar "WARMUP ASSIST" switch. That would allow fast warmup to idle-stop mode in the winter, and maximum power and efficiency (using the stock cold air intake system) once warmed up.
    Has anyone tried either of those ideas? I know warm-air intakes are quite common in the Insight community.
    49,401
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    There already is a device in the coolant path called a thermostat. It operates automatically.
    Exhaust heat recovery existed for a long time on a LOT of engines but I think they were eliminated when their usefulness was found to be tiny compared to the cost of maintenance.
  4. dolj
    dolj Senior Member
    7,634
    3,851
    Wellington, New Zealand
    Doesn't the Gen 1 already have such a system as standard?
  5. ChapmanF
    15,509
    Not that I recall.
  6. ammdb
    ammdb Active Member
    266
    110
    Indianapolis
