Unable to activate Services Connect features
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Ken789, Oct 28, 2023.
  1. Ken789
    Ken789 Junior Member
    New England
    2023 Prius Prime
    XSE
    Surely I am not the only person to encounter this. Cannot get the app to fully link with the vehicle and active the Drive Connect services. It links to the app but then returns an error message with a Contact Support button and neither Services Connect support or the IT team they escalated it to nor Brand Engagement can figure out why. They attempted to completely remove and reset my profile on their end but that has not solved the problem either. Aside from that error message, the app states I have no subscriptions available but they consistently report they see all the included subscription trials active on their end and cannot figure out why I cannot see them and cannot access them.
    Anyone????
  2. Kevin H Tran
    Kevin H Tran Junior Member
    Santa Clarita
    2023 Prius
    XLE AWD-e
    I have the same problem when I picked up my XLE this weekend. Looking for help too.
  3. Argyros
    Argyros Active Member
    275
    142
    2023 Prius
    That happened to me at the dealer; a specialist had to come out and help the salesperson hook it up. They tried several times, and still got the same error message; the only way they finally got it set up was that he went through 'the back end' of something where I couldn't follow to get it done. I would suggest you go back to the dealer to get it resolved. I hope your dealer has an expert there as well for the Connected Services.
    Danno5060 likes this.
  4. Kevin H Tran
    Santa Clarita
    2023 Prius
    XLE AWD-e
    I was able to get my connected services to finally link up. There is a video on youtube that can help you set it up.
    Since I am still new, I cannot send links until I get to 4 responses.
    The process is straightforward and hopefully works for you.
    #4 Kevin H Tran, Nov 8, 2023
  5. jeremnyc
    jeremnyc Junior Member
    95
    2023 Prius
    Try turning the car off and on again. It may allow the code to send...
  6. Mendel Leisk
    41,911
    Type out the title?
  7. Kevin H Tran
    Santa Clarita
    2023 Prius
    XLE AWD-e
    Initial set up of the new Toyota multimedia system. QR code and easy start up- Steve Clifford
    vvillovv likes this.
  8. George Jetson
    George Jetson Junior Member
    Moneta, VA USA
    2024 Prius
    I’m new here and I’ve been having the same issue. I’ll give this a try.
  9. Kevin H Tran
    Santa Clarita
    2023 Prius
    XLE AWD-e
  10. scottmksmk
    scottmksmk Junior Member
    Western, NY
    2024 Prius Prime
    SE
    Can't connect here. Picked up a Prime SE this weekend. Get an error that I have no subscriptions. Tried all the tricks (uninstall, reinstall, delete app, reload app, scan QR, enter manually, remove vehicle, reenter vehicle) and nothing. Put a ticket in with Toyota. I did have it linked to my account before picking it up so I don't know if that screwed anything up.
  11. Jabog6
    Jabog6 Junior Member
    32
    16
    CT
    2024 Prius Prime
    SE
    I had a similar problem, and I also had created an account before. It took Toyota a few weeks after I called for them to figure it out.
  12. scottmksmk
    Western, NY
    2024 Prius Prime
    SE
    I was able to connect once Toyota looked at the ticket I submitted and added the services. Everything works fine now.
  13. Kevin H Tran
    Santa Clarita
    2023 Prius
    XLE AWD-e
    Funny thing, after I got my second key, I got a letter from Toyota to schedule an appointment for my second key.
