Unable to read the map SD Data
Discussion in 'Gen 4 Prius Audio and Electronics' started by PriusRos, Oct 16, 2023.
  1. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    My navigation system on my 2016 Prius has stopped working. When I turn on the car, the map will usually come on screen for a couple of seconds, then the following message is displayed:
    Unable to read the map SD Data.
    Check the map SD.
    If necessary, consult your dealer.
    It had been doing this on and off for a number of months but would usually come back on when I restarted the car and stay on. Now the map is gone completely.
    I've removed the SD card, cleaned the contacts, and reinserted it. Doesn't make any difference. I think I bought the SD card in 2020 and it had a 2019 map.
    My question is, does this error look like it's just a problem with the SD card that an updated map would fix, or could it be a problem with the card reader?
    Thanks for any insights/experiences with this problem.
  2. sylvaing
    sylvaing Senior Member
    1,210
    514
    Did you throw away the old card? If not, try it and see if it works.
  3. PriusRos
    1,973
    218
    Rockville, MD
    I probably didn't throw it away because I tend to keep everything, but I don't know if I'll be able to find it! Good idea though.
  4. PriusRos
    1,973
    218
    Rockville, MD
    Update:
    I called my local Toyota dealer and asked whether this message indicates a bad SD card or something more serious. He told me I would need to bring it in so they can check it out. When asked how much that would cost, he said the diagnostic check is $150. Well, my map needed updating anyway, so I might as well try installing a new map first to see if the problem is fixed, so called the parts department to ask how much the updated map costs. He told me $150. I asked for the serial number, went on Amazon and bought it for $26. Popped out the old SD card and put the new one in. The new map came up immediately and has been working ever since. :LOL:
  5. PriusRos
    1,973
    218
    Rockville, MD
    Update:
    sylvaing likes this.
  6. PriusRos
    1,973
    218
    Rockville, MD
    Update:
  7. PriusRos
    1,973
    218
    Rockville, MD
    Sorry about the repeat replies. I don't know how to delete all the duplicates.
  8. bisco
    52,361
    congrats!
  9. Brother A
    Brother A Junior Member
    Earth
    Hey @PriusRos, Glad this worked. I am looking into updating my Nav Map on my 2017 as well. Can you send a link of the MicroSD that you bought? And was it a new map - like 2022 or newer? Thanks.
    striker308 likes this.
