Unable to remotely start up ac
Discussion in 'Prime Main Forum (2017-2022)' started by kaiotes, Jul 10, 2019.
  1. kaiotes
    kaiotes Junior Member
    2013 Prius Plug-in
    I have an 18 prime. I brought my car to the dealer for regular maintenance and to help me figure out why I can't get the remote ac feature to work. Was told that the battery must have at least 1/4 for it to work.
    Is this right? So what they are saying is if I don't charge my car and if it is always empty this function is completely useless?
    I have a phev Clarity and have never charged it since it's purchase and have not had any issues w this function.
    They want to keep my car for further diagnosis but I am a little shocked that it requires juice.
  2. schja01
    schja01 Senior Member
    1,843
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    Well you’d need enough to run the heat pump for whatever the max duration is. 30 minutes? ??
    52,371
    wasn't your pip the same way?
  4. thefranchise713
    thefranchise713 Junior Member
    75
    52
    Buffalo, NY
    2018 Prius Prime
    In your use case, and mine--yes, the remote AC feature is useless. Even when it works I've found it pretty terrible.
  5. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    It is an electric HVAC system. All the power for running this comes from the battery via the DC-DC converter. If the battery is empty, then the ICE would need to run and they likely didn't program that. They don't want somebody starting the remote AC and the car in an enclosed space, for example.
  6. kaiotes
    2013 Prius Plug-in
    Why can't they use the regular battery for this or take a look at how Honda designed their clarity. No issues w this feature on the clarity. I never tried using this on my old pip that I have already sold.
  7. kevin.c
    kevin.c Member
    98
    76
    sf bay area
    I thought the Lexus remote A/C didn’t have this limitation. Although it seems like that one only runs for 10min instead of 30: Lexus Enform Remote | Lexus Drivers
  8. jb in NE
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    This would quickly deplete the 12V battery, if that is the “regular” battery to which you refer. It has a very small capacity.
    drash likes this.
  9. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    You are correct. The Lexus Enform Remote app does not have this limitation. The Toyota Entunes app remote climate for the Prime Advanced also requires some charge left in the battery. Both run for 10 min. The difference on the Lexus is you have to have your A/C preset. On the Prime Advanced I can set it via the app to max cool or max heat. Both systems require the doors to be locked.
    The Aux battery (12V) doesn’t have enough juice to keep the lights on for 10 minutes let alone run an HVAC system.
    If you are talking about using the Remote A/C function from the fob that also runs for 10 minutes as noted in the owner’s manual (pg. 510). Also that requires the HVAC system to be preset before shutting the car off.
    If you really want to use the remote climate you either have to plug it in for 30 minutes or use the Charge Mode while driving home or to work or school for 7 minutes (maybe 5, YMMV). Since I’ve used that exactly twice you may have to experiment.
    iPad ? Pro
  10. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    How Honda and Lexus remote AC work when the traction battery is depleted? Do they start ICE remotely to replenish the battery charge?
  11. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    Oh yeah. Since my wife’s NXh is a hybrid the ICE starts up after the usual 8 seconds. If she leaves the front defroster on the ICE kicks on immediately. She’s never used the Remote Start for summer and A/C, just winter and heat.
    It does work reliably and because it’s a hybrid once the ICE hits operating temperature, it shuts off.
    iPhone ? Pro
  12. Salamander_King
    11,024
    8,970
    New England
    So, it is basically a remote engine starter for the hybrid Lexus. For PRIME, you can not get the ICE to start while plugged-in, by remote or in a car. That is another limitation. I wonder how Clarity works when the car is plugged-in?
  13. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    Yep that way Lexus can keep the same remote function whether it’s a straight ICE or a hybrid. Probably why they are so reluctant to go to plug-ins. The Entunes app for the Highlander Hybrid can also do remote starts as well but it may be limited to the Limited Platinum version.
    IMO the Entunes app for Prime may be designed this way on purpose. I’m betting they are going to a full EV in the future. Took them 5 years to double the battery on the Prime and redesign it. By 2022 we’ll get a BEV Prime, but it may not look the way people think.
    iPhone ? Pro
  14. Salamander_King
    11,024
    8,970
    New England
    I read in other thread, that for 2020 PRIME, addition of CarPlay resulted in omission of Remote App on Entune.
  15. drash
    drash Senior Member
    2,586
    1,328
    Upstate NY
    Yeah you are correct, not listed anymore. One of the big reasons I won’t be getting a new one anytime soon. Nice you can remotely check on how much time is remaining on charge, initiate a charge, start remote climate with max heat or max cool, etc.. Weird because my wife’s NXh has Apple CarPlay and Enform Remote so you know it can be done. Maybe they pulled it to redesign it as strictly a remote app ala Enform Remote.
    iPhone ? Pro
    Blauer Glimmer likes this.
  16. CharlesH
    2,797
    1,165
    Roseville, CA
    This seems to be just asking for a lawsuit when someone remotely starts the ICE in an enclosed area and someone dies from CO poisoning. Unless they are counting on newer cars producing so little CO that it is not a danger anymore. But usually the Toyota lawyers force pretty conservative policies (like the idiotic locking out of most of the NAV functionality when moving, even when there is a passenger to operate it).
  17. Salamander_King
    11,024
    8,970
    New England
    Remote engine starter is quite popular in colder climate to pre-warm the cabin. It is not an option for PRIME, but doesn't Toyota offer that option on other cars? I never owned a car with a remote engine starter until recently purchased Pathfinder. It came with a manufacture-installed remote engine starter.
