Uncomfortable Over-Revving Sound on Long Hill
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by William Redoubt, Sep 25, 2016.
  1. William Redoubt
    William Redoubt Senior Member
    1,215
    1,165
    Coronado Island, California
    Once a week I drive down a long hill (from Beaumount, CA to San Jacinto) after a long cruise on the freeway from the Palm Desert area. The battery achieves "full" charge about halfway down and it sounds like the ICE begins to rev a a high RMP even though I am not pushing on the accelerator. If I push on the accelerator, the ICE kicks in and the sound stops until I let off.
    I am assuming this is normal, but want to confirm it with others.
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,779
    So. Texas
    Yup, normal. Since the battery is full, the ICE is being used to burn off excess regen from the long downhill.
    RCO and Coast Cruiser like this.
  3. Mendel Leisk
    38,726
    I've heard the car will do some "B mode" revving, even if B is not selected?
  4. fuzzy1
    10,170
    Yes, it is normal. The engine is spinning up a bit for engine braking. If you are in 'D gear', it isn't really spinning up very much, probably not much over 2000 RPM. This car-engine combination just happens to be noisy, so you hear it more than some other cars.
    Try putting it in 'B' for a bit as a test -- it will spin up much faster and louder, various people have likened it to a jet engine, giant vacuum cleaner, or screaming banshee. Some of my hills push it up to 4600 RPM. But the engine is still safe. If it causes your car to slow down more than you want, then the hill isn't all that steep.
    My descriptions are for Gen3. The Gen4 won't be identical, but should be similar.
    While the engine braking concept in 'D' is the same as in 'B', the degree of braking is very different. On one of my occasional hills, 'D' hits 2000 RPM but not with enough braking force to stay down to speed limit, while 'B' hits 4600 RPM and can hold to speed limit.
    #4 fuzzy1, Sep 25, 2016
    RCO likes this.
  5. Trollbait
    11,560
    When engine braking, the ICE valves are left open, which allows large amounts of air to pumped through it. This provides extra resistance to the drive train to help in decelerating, but also makes more noise.
    RCO likes this.
  6. fuzzy1
    10,170
    I don't believe the valves can be left open. But, being variable, they are adjusted for maximum pumping resistance.
  7. Tideland Prius
    16,155
    Yup normal. The higher rpm is to compensate for the loss in regen when you have a full battery. It's trying not to let the car run away down the hill basically. When you get to the bottom and level out, it may still rev higher than usual as it tries to bleed the battery (a bit silly, I know. Once I was at the bottom and hit a red light and I was just sitting at the traffic light with the engine revving up. Good thing there were no pedestrians or I might've gotten some awkward looks).
    alanclarkeau and RCO like this.
  8. Mendel Leisk
    38,726
    I've noticed after descending Seymour in our 2010, battery full to the gills, subsequently running along that rolling 60km zone, our 2010 will stay in electric-only even with the Hybrid Synergy Display bar slightly to the right of median (the typical cut-off point for electric-only).
    RCO likes this.
  9. Tideland Prius
    16,155
    Yup. It'll try to use it so it's back down to 6 bars. I'll try to milk that extra charge for as long as possible, accelerating slowly or gliding.
    alanclarkeau, RCO and Mendel Leisk like this.
  10. Trollbait
    11,560
    It can close them, or at least one side, to reduce losses while the ice is off and spinning.
  11. William Redoubt
    1,215
    1,165
    Is there any issue with oil starvation or reduced oil pressure?
  12. Mendel Leisk
    38,726
    Does engine braking equate to high vacuum? That usually means better pulling up of oil into the upper cylinder region I think.
  13. ChapmanF
    15,614
    VVT-i stands for Variable Valve Timing (i for "intelligent", meaning the ECM controls it). That's the only trick it has up its sleeve. It can change valve timing within a certain range, and only on one cam (the intake). Doesn't have a way to just leave them closed, to my knowledge.
    Toyota has built some engines with VVT on both cams, and some with "Valvematic", which does allow control of valve opening amount as well as timing. Before Gen 4 was announced, I was sort of hoping it would use that, but I don't think that happened. If what I read is correct, the 2ZR-FAE has it, but the 2ZR-FXE Atkinson version still doesn't, even in Prius Gen 4.
    -Chap
    RCO likes this.
  14. Mendel Leisk
    38,726
    Our previous Civic Hybrid had two cam lobes for each valve (again, intakes only?). The majority of time the valves were at the regular lobes, but under heavy load hydraulics would shift in the second, higher lift lobes. Doing something like accelerating up a hill you could feel it kick in.
  15. Tideland Prius
    16,155
    Yeah, that's the difference between Honda's VTEC and other manufacturers' variable valve timing mechanisms. I haven't delved deep into this but just off the top of my head, I can't think of another manufacturer that uses two different cam lobe profiles.
    Edit: lol. Oops. I guess Toyota's VVT-iL in the Celica was similar in principle to VTEC.
  16. Trollbait
    11,560
    If the engine is soinning, the oil pump will be too.
    Perhaps I am misremembering a discussion on the butterfly valve position
    Which had all my friends calling the Honda engine a V4:mad:
  17. Tideland Prius
    16,155
    All my friends when we were in high school assumed 4 cylinders were in a V shape.
    RCO likes this.
  18. Trollbait
    11,560
    Does anybody actually look under the hood anymore?
  19. Mendel Leisk
    38,726
    Supra was a straight 6.
  20. Tideland Prius
    16,155
    I think that statement was valid beginning 10-15 years ago lol
