Uncontrolled Acceleration
Discussion in 'Gen 2 Prius Main Forum' started by Tripod137, Nov 6, 2007.
  1. Tripod137
    Tripod137 New Member
    145
    Long Island
    I had a short entrance ramp to the parkway. I waited for my opening and floored it. Got on up to speed w/ no problems so I relax a bit....but the car keeps accelerating! So I disengage the cruise control (I didn't remember hitting it)...but that didn't work it was never on...so I tap the brakes and the car slows a little, but the engine is still revving. I take my foot off the brake and the car starts accelerating again! It was rush hour traffic, but no one was in front of me, luckily. I push harder on the brakes and the car slows down some...but the engine is still revving high! I release and reapply...the car still wants to accelerate (my 2 yr old is in the back totally oblivious). Then I push a little hard on the brakes and, I guess, the emergency stopping thing kicks in and the car shakes and slows down a lot. But the engine is still revving....so I figure...lets see if the gas pedal is stuck. I switched feet on the brakes and tried to pull up the pedal with my toe. The car starts to slow down! and no more revving!
    It seems as if, after my last car wash, my winter floor mats (that I use all year round) slid up a little far towards the pedals and when I floored it, the gas pedal got stuck under the edge of the mat and "kept the gas on".
    Need to keep on up my floor mat position and be mindful of when I floor the gas, it could get stuck.
    It made for an interesting few seconds of my evening. I am still wondering why I didn't start to freak out....maybe if the "toe under the gas pedal" thing didn't work....
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    There have been other reported problems with floor mats.
    Tom
  3. PoulStaugaard
    PoulStaugaard Now a PriusOwner
    95
    Copenhagen, Denmark
    How about shifting into neutral ? Won't that do it - The Prius throttle being computerized ?
  4. Tripod137
    145
    Long Island
    <div class='quotetop'>QUOTE(PoulStaugaard @ Nov 6 2007, 04:49 PM) [snapback]535733[/snapback]</div>
    The Engine won't rev like crazy being in neutral?
  5. Neicy
    Neicy Member
    834
    Wakefield, MA.
    In that case it would have continued to rev, but the gear would be disengaged and you would slow down. I believe a safety warning was issued recently regarding mats/rugs on some Toyota vehicles; that when using one set on top of another they may not stay in the clips and move.
  6. Tideland Prius
    16,123
    <div class='quotetop'>QUOTE(Tripod137 @ Nov 6 2007, 02:08 PM) [snapback]535749[/snapback]</div>
    Not on a Prius. Try it. When you're stopped, shift to N and depress the accelerator. Nothing happens.
  7. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 6 2007, 06:00 PM) [snapback]535779[/snapback]</div>
    Hmm, what about the other way around. If I step on the accelerator to get the ICE revving, and then shift to N, will it maintain the current RPM, or will it drop to idle? Maybe I'll try it on the way home tonight.
  8. Tech_Guy
    Tech_Guy Class Clown
    868
    123
    Silicon Valley, CA --- Land of Fruits & Nuts
  9. clintbhs02
    clintbhs02 New Member
    32
    Something similar happens to me when I have the car in cruise control, then go to hit the brakes.. its takes like 3 seconds to make up its mind to stop (and right before it starts to stops it seems like it accelerated)
  10. Neicy
    Neicy Member
    834
    Wakefield, MA.
    <div class='quotetop'>QUOTE(Tideland Prius @ Nov 6 2007, 07:00 PM) [snapback]535779[/snapback]</div>
    Wow! Didn't know that. Thanks!
  11. Neicy
    Neicy Member
    834
    Wakefield, MA.
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    yep i have done the floor mat thing three times. the first time it was scary, the 2nd time, was done on purpose to see how often it would happen... (most of the time), the third time was a fluke because after the first two times, i began practicing giving it the gas without going all the way to the floor and got pretty good at it... mind you, flooring it is not a common need for me.
  13. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Tripod137,
    You should really remove the drivers side floor mat until you can find the hooks with the prongs that plug into the floor of the car, and install the hooks. Be sure to hook the mat on the hook portion that sticks up of each hook. Takes a few seconds to do, but the consequences of not using the hooks can be very negative.
  14. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Were your winter floor mats hooked properly into the hook on the floor which keeps the mats in place?
  15. Tripod137
    145
    Long Island
    <div class='quotetop'>QUOTE(ryogajyc @ Nov 6 2007, 09:20 PM) [snapback]535896[/snapback]</div>
    The winter floor mats are some aftermarket brand w/ no holes in it for the hooks. The cloth mats have the holes for the hooks and are engaged w/ them. the rubber mats just sit on top.
    If I remove the cloth mats....and just put the rubber mats in (right now I have both installed), will the rubber mats break the hooks by lying on top of them?
  16. Stevep
    Stevep Junior Member
    77
    Orlando, Fl
    <div class='quotetop'>QUOTE(Tripod137 @ Nov 7 2007, 08:48 AM) [snapback]536091[/snapback]</div>
    Try putting a couple of holes in the rubber mats. Then you can replace the cloth mats with them and hook it on the hooks.
  17. Danny Hamilton
    926
    94
    <div class='quotetop'>QUOTE(Tech_Guy @ Nov 6 2007, 06:39 PM) [snapback]535806[/snapback]</div>
    Great links on how the Prius accomplishes its CVT behaviour. I've seen them both before, but I enjoyed the review. However, your post implies that they have details about how neutral works in a Prius. I didn't see anything in either of the articles you linked to that describes what happens when the Prius is in Neutral.
  18. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    <div class='quotetop'>QUOTE(donee @ Nov 6 2007, 06:40 PM) [snapback]535866[/snapback]</div>
    Hooks?? What hooks??? Since I bought the car there's been a hole in the floor where something should go, I guess the dealer forgot to install the hooks or something. Now there's a record that they forgot to install the hooks so when I'm killed by the floor-mat-on-the-gopedal syndrome my survivors can sue the dealer for a zillion dollars. Maybe Toyota should send the clips to every owner, they might save money by keeping runaway Prii from killing people.
  19. Tripod137
    145
    Long Island
    <div class='quotetop'>QUOTE(Stevep @ Nov 7 2007, 09:49 AM) [snapback]536118[/snapback]</div>
    Woooohooooo!!! My rubber floormats have a few punchouts in them for insertion of the hooks! Also...the Prius floormat hooks (maybe all cars have this) are on little arms that swivel so they can be easily adjusted for different floormat hole positions!!!
    They are kinda like this...
    |________________
    Swivel ----^
    Thanks guys!!!
    Man I love this place!
  20. Danny Hamilton
    926
    94
    <div class='quotetop'>QUOTE(abq sfr @ Nov 7 2007, 12:17 PM) [snapback]536195[/snapback]</div>
    Nah, there is also now a record that you knew there should be hooks, and that you knew that without the hooks there is a risk of being killed by floor-mat-on-the-go-pedal syndrome. Since you haven't taken the car to the dealership to have the hooks installed, you have implicitly accepted that risk. Therefore you have eliminated Toyota's liability in the matter.
