Underbody panels
Discussion in 'Gen 3 Prius Main Forum' started by Fitcious, Jun 8, 2020.
  1. Fitcious
    Fitcious Member
    195
    88
    Los Angeles
    Found some threads on underbody panels. Noticed one of mine is coming off- is the best bet to either buy from dealership or look for junk yard? Will ct200 have identical panels? Thanks!
  2. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    CT200h has a different body shape, so I wouldn't think they would be the same. Dealers are very expensive for these, a junker's would be cheaper.
    Fitcious likes this.
  3. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    Check if the push pins are missing first, that will save you from buying panels.
    kithmo and Fitcious like this.
  4. Fitcious
    Fitcious Member
    195
    88
    Los Angeles
    I checked and unfortunately it isn’t the pins. It’s the panel.
    The circular area where the pins go is torn, so it isn’t a full circle, think of it as a half moon; so the pin doesn’t stay and part of the panel just hangs
  5. Mendel Leisk
    41,901
    Look into "fender washers", galvanized or stainless.
  6. Mendel Leisk
    41,901
    Even a regular washer diameter (not oversized) would probably be effective. Or a short section of plumber's pipe hanger strap? You may need to drill-out the ID of whatever you use, slightly. You want it to closely match the original hole diameter.
    Panel and fastener part number info:
    SUSPENSION CROSSMEMBER & UNDER COVER. 2013 Toyota Prius Four HYBRID | Toyota
    (click on "view more images", for the frontmost panels)
    And for the piece directly behind the front fairing:
    FRONT BUMPER & BUMPER STAY. 2013 Toyota Prius Four HYBRID | Toyota
    #6 Mendel Leisk, Jun 8, 2020
  7. Mendel Leisk
    41,901
    Geez I can't let go:
    One possible issue with adding a washer, it increases the thickness the fastener has to go through (the "grip"), and might make it difficult for the fastener jaws to work properly. Considering that, a very thin washer, say just a snipped out square of aluminum flashing material with a hole drilled through, or some sort of thin/concaved washer, might be best.
    McMaster-Carr
  8. Yimuzi.
    Yimuzi. New Member
    Kansas
    Besides finding alternate push fasteners, most people have an unlimited stock of aluminium washers in the fridge. Thin gauge cuts with scissors. Coke cans
