Underlying Cause of Head Gasket Failures?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rjparker, Jul 29, 2021.
  1. rjparker
    rjparker Tu Humilde Sirviente
    10,480
    6,567
    Texas Hill Country
    We seem to be in full crisis mode on gen3 head gasket failures with some hg repairs failing as well. I am sure many failures end up at auto auctions and then are flipped with block sealers based on the number of buyers having problems.
    The gen3 engines are known oil burners, egr cloggers and depend on knock sensors since they have 13 to 1 compression but use regular gas. At the same time most run fine for well over 125k-200k miles before the rattles began. It is unlikely gasket materials or clearances are the root cause when they last that long.
    Could detonation knocking caused by carbon buildup, lean fuel mixtures, failing knock sensors, egr clogging and or poor octane be likely suspects when overheating is not the issue?
    The gen4 1.8 engineering seems to offer clues. Toyota redesigned upper cylinder cooling through use of steel and foam spacers, increased cylinder turbulence, changed the intake to improve egr flow, revised the egr cooler size and location, all of which can reduce knocking which blows head gaskets.
    So do we just trade gen3s at 150k, always run premium fuel (one trusted mechanic's advice) or build up an engine repair fund?
    #1 rjparker, Jul 29, 2021
  2. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    impossible, the priuschat moral police would have stopped & jailed the perps even before gasket sealant is poured in! Your giving permission for people exercise such practice.
    #2 Grit, Jul 29, 2021
  3. Mendel Leisk
    41,875
    Cleaned the intake manifold, EGR circuit, installed oil catch can(s), just past 70K kms. Will likely revisit the EGR with the spark plug change, at 12 years, and likely around 100K kms.
    Not burning ANY oil so far, doing 6 months oil changes, at undisclosed kms (don't want to be hauled off...). At oil changes I put in 4.2 liters, and it's about 1/8" below top mark on dipstick. When the next oil change rolls around, hasn't budged.
    Grit likes this.
  4. fuzzy1
    10,602
    That is the expansion ratio. No normal Prius has anywhere near that much compression.
  5. rjparker
    10,480
    6,567
    Texas Hill Country
    A Prius has control over its compression ratio and mimics a variable displacement engine through valve timing. 6.5:1 compression stroke and a 13:1 power stroke.
    As we have discussed before, the variable valve timing provides variable compression ratios. The ratio on the power stroke is at least 13/1 no matter what you call it. Knocking can and does happen. Add carbon and knocking increases.
    The point of the thread was "what is going on with gen3 head gaskets". Knocking is a known factor in head gasket failures. Many other factors are likely including thermal cycling which may allow failures, another factor which Toyota worked on in gen4 with the foam and steel spacers.
    Nevertheless I agree with Jzchen's earlier viewpoint on knocking:
  6. ChapmanF
    18,514
    What is happening on the power stroke is that the charge is expanding. As fuzzy1 correctly pointed out, the ratio by which it expands is known as the expansion ratio.
    The charge is only being compressed on the compression stroke, and the valve timing makes that ratio less than 13:1. That's what makes the engine an Atkinson-cycle engine: the fact that its expansion ratio exceeds its compression ratio.
    The engine does indeed have a knock sensor, like pretty much any other modern engine, and does have to be able to react (such as with ignition timing) to keep itself out of knocking conditions, like pretty much any other modern engine. None of that is because of "13 to 1 compression", which it doesn't have.
  7. ETC(SS)
    7,336
    If you replace the head gasket without addressing the root cause of the head gasket failure, it's "probably" going to fail again, don't you think?
    It's easy to blame the OEM for building a car that won't last much more than 120,000 miles with a 10,000mile OCI, and modern drivers that pretty much expect to maintain a closed-hood maintenance philosophy.
    There ARE some design issues with the G3, as there are with any car.
    IMHO the EGR circuit is prone to getting plugged up, the oil sump is about a quart too small, and the OCI is too long.
    The pistons are well documented as well.
    You CAN inform yourself of some of the design issues with the G3 and mitigate some of the those by doing some of the things we talk about in this forum...like oil catch cans, reduced OCI, and oil level checks at least as often as required by the OEM.
    Most people don't.
    They sell the car at some point and owner #2 gets an unhealthy middle aged car with almost a 100 percent blockage of the left anterior descending (LAD) artery.....commonly referred to as....a widowmaker.
    Next thing you know....the G3 Prius get the same reputation for quality and longevity as Fiat. :ROFLMAO:
    Remember that the cars are built in Japan, and they generally do not amass the same number of miles that their US spec card do, AND YET the Japanese also have used Priuses quite successfully as fleet vehicles (taxis) as have companies in the US.
    Just a guess here, but fleet operators (even MINE!) have different maintenance modalities than private (gas and go) drivers.
    THIS is why.....ACTUAL mileage WILL vary. ;)
    douglasjre likes this.
  8. bisco
    52,362
    do we have a conclusion yet? i've got almost 25,000 miles on my engine, and i'm getting nervous...
  9. rjparker
    10,480
    6,567
    Texas Hill Country
    I am doing my best to wake up the community. Answers like it is "normal" are pretty sad.
  10. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    i’m nervous about the hv bat not getting charger cycles if you got 25,000 miles only on the car
  11. ETC(SS)
    7,336
    He has a pip.
  12. bisco
    52,362
    i am a pip
    if only toyota would disclose the truth, i'm sure they know the facts
  13. ETC(SS)
    7,336
    Concur.
  14. Mendel Leisk
    41,875
    The dots I connect:
    1. Cylinder 1 is where predominance of 3rd gen gasket failures start.
    2. The intake manifold’s EGR capillary passage for cylinder 1 always seems to clog first.
    douglasjre and bisco like this.
  15. Kenny94945
    Kenny94945 Active Member
    857
    433
    Sausalito
    2016 Prius v wagon
    Um, interesting question and discussion.
    I venture to say in many cars head gasket failure is attributed to water jacket location or high compression (or an over heat condition).
    Coolant flushes can be a good maintenance item to reduce risk.
    I don't recall anyone every mentioning re-torqueing the head bolts.
    A common initial critical fastener check on motorcycles as a general example.
    Predicting failure can be futile.
    So, I could suggest a head bolt re-torque at an initial 10K service and a follow up at 50K.
    But, I have not done this nor am I too concerned.
    FWIW
    Have fun.
  16. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Since you have a GEN 4 Prius and not a GEN 3, that is a consensus view.
    JeffD
  17. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    Well, the service procedure for cylinder head installation shows a "torque + angle + angle" sequence on the head bolts. So they are torque to yield (or torque to angle).
    What would you have the head bolts "re-torqued" to?
  18. Mendel Leisk
    41,875
    His 2016 Prius v would have a gen 3 engine, identical to 2015 Prius I think. That said, I wouldn't touch head bolts.
  19. fuzzy1
    10,602
    I had understood that only the 2016 Liftback was a Gen4. The 2016 'v' and 'c' were still Gen3s.
  20. wheezyglider
    wheezyglider Active Member
    247
    178
    SF Bay Area
