Underpan
Discussion in 'Gen 3 Prius Main Forum' started by bossless, Sep 24, 2010.
  1. bossless
    bossless New Member
    Has anyone had a problem with the plastic underpan? The flap that gives access to the oil drain plug and filter broke off. I think it must have been defective, but am not sure.
  2. samsprius1
    samsprius1 Active Member
    711
    172
    2023 Prius
    Limited AWD-e
    Who changed your oil last?? Is a good place to start!! there are plastic push pin clips that hold it up!! I have broke these clips. you can get clips at autozone or O'reillys auto
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    There have been a few others that have complained about the same. I will see if I can find the thread...
  4. almypal26
    almypal26 Member
    101
    So Cal
    I had a similar problem with the plastic piece just behind the pan you're refering to. I was driving home from Arizona, and only found out of the problem when I pulled into a gas station (because it was dragging on the ground). One or more clips must of broken off while on the highway, and unbeknownst to me, part of the plastic (due to the speed of the car - 65/70 mph, couldn't here the sound at that speed) bent backwards. The front portion of the plastic came off, and I'm not sure why the entire piece didn't fall out. I took it to LONGO Toyota, thinking this was going to cost me a pretty penny. The service writer was able to get Toyota Corp. to replace under warranty. Hope that helps.
