Unhappy and Disappointed in my 2012 Prius C
Discussion in 'Prius c Main Forum' started by czhuang, Apr 19, 2018.
  1. czhuang
    czhuang New Member
    New York
    Hi everyone! This is more of a rant thread but I'm also seeking advice:
    This is my first Prius and it's always been my dream car! I bought my 2012 Prius C used, two years ago with 99k miles on it. For the first year I was in love with the car and I WANT to love the car, I absolutely baby it and get the oil regularly changed, got new tires etc.
    Now it has 120k miles on it and I've been losing faith because I'm noticing SO many issues with it. Mainly, I feel like the Prius was cheaply designed, the plastic interior rattles when I drive on bumpy roads or play music. The outer body is easily dented and scratched, it seems. I have to park in huge lots for work and so other people bumping into the car is inevitable, but it seems that every day there is a new dent (seriously).
    On startup, there's a loud, unexplained rattling noise coming from other the hood. I'm aware this might be due where I live (New York) and the cold weather conditions there for nine months of the year but it only adds to my feeling of insecurity in the car. I plan on changing the filter soon to see if this helps.
    The brakes have a this high-pitched squeak/whine when I back up, I've gotten this checked by a dealer and was told it was simply rust, which they cleaned off. I had to replace one of headlights and one of my tail lights recently due to splits in the plastic cover.
    I guess overall, Prius maintenance is more than I expected it to be and I'm disappointed in all the problems I seem to be encountering with it since Toyotas are touted as an incredibly reliable brand.
    Am I just experiencing normal issues that an older Prius with over 100k miles on it would run into? Am I crazy? What should I be doing to maintaining an older car with that many miles on it?
    Thank you for reading and any recommendations you might make! :)
    49,500
    i'd say you got a lemon. unfortunately, some prius have bad squeaking problems, not sure why. a lot has been written on finding and solcing with different types of padding between the plastics.
    dents and scratches from other cars are pretty normal imo, most cars won't do well with being whacked.
    the rattling noise is a concern, does it happen every time?
    if cleaning the brakes eliminated the squeal, the answer is to put the car in neutral and brake gently now and then. that eliminates regen, and allows the pads to scrape the rust off the rotors. this is a common prius problem because the friction brakes are rarely used.
    headlight and taillight splits are less common and unfortunate.
    all the best!(y)
  3. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    How is it even a lemon when there is basically no issues with the car running at all? lol
    Other than that sounds more like buyer's remorse
    1) cheaply designed - duh, it's a econo-car and didn't you get a peek at it before buying? there is a lot of plastic inside, but why do people hate plastic so much? I guess MFG's should make interiors out of glass (like phones nowadays for "premium"), so people can oggle at the shiny premiumness of their econo-cars until the first drop/break?
    2) rattling - don't think I've been in a econobox that didn't rattle ere and there
    3) easily damaged - lol, ALL cars are easily damaged unless you park in the middle of no where 1000 miles away from any other human/object that can touch your car...how was this even a argument?
    4) loud rattling start - you're in New York, cold starts = rough starts no matter the car
    5) brake squeal - I've heard brake squeal in almost all used cars (made worst in snow belts)
    6) light - I guess this is the only valid lemon/defect...since my tail light (and seems other members) seal did go bad and there was condensation build up in one of the tail lights (though lights still worked)
    So the only maintenance you did was still just tire and oil/filter change...apart from the taillight/headlight seal issue - Buyer's remorse and I think you should move to a less populated warmer state
    Kim Hollowell and edspecR like this.
    49,500
    true, but some cars rattle, and some don't.
    a loud rattling noise under the hood can't be normal.
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    120k miles in the salt and snow... that in itself is rather impressive to have nothing replaced at this point... ;)
  6. Darken
    Darken Active Member
    553
    49
    PA Dutch Country
    Hi Czhuang,
    Sorry to hear you are having issues with your Prius C. I think the quickest answer to your question aside from the rant is Yes for the most part you are experiencing things that are going to pop up from owning an older econo Prius. This is probably not something you want to hear, but most of what you describe are pretty normal things that you can run into with any vehicle let alone a used one. (aside from the light situation)
    Hopefully aside from the noises your finding the car is giving you good gas mileage and reliability? I know what it's like to want a vehicle really bad and then once getting one finding my enthusiasm slowly dying over the months of ownership. Not sure if it's buyers remorse or failed expectations. :rolleyes: This has certainly never happened with any of my Prius vehicles though.:D Best of Luck.
  7. mohsin
    mohsin Member
    91
    61
    Dubai, UAE.
    2014 Aqua
    I recently had similar episode, my car was making such weird noise on cold start that i thought it was bad bearing in transmission.
    However, it turned out to be loose "exhaust pipe shield" matter of tightening few bolts. From what i have read this seems common.
    ztanos and fotomoto like this.
  8. zen_
    zen_ Junior Member
    29
    Midwest
    2014 Prius c
    A good, trustworthy independent mechanic + doing what DIY repairs you are capable of is the most economical way to keep a high mileage vehicle rolling. As a vehicle owner, you do need to have some knowledge of car components, common problems / wear items, and very basic troubleshooting to at least communicate effectively with mechanics. Many owners with none of that get put in the trap of describing extremely vague problems to a dealer service writer, and in turn, not having the problem fixed and / or being raked over the coals for unnecessary services.
    I don't want to sound dismissive of the issues you have had, but they all seem pretty minor. It's an economy car this is mostly plastic, and the rattles might be exacerbated by worn suspension components or poor riding tires after 100K miles. The brakes might still be original rotors and pads that are toast, or cheap after market parts, and certainly rusty from Northeast winters. The rattle from the engine area might also be exhaust heat shields that are rusty as another member suggested.
    Cars that go 200K+ miles without major problems achieve that with proper maintenance. Virtually no one achieves those numbers just changing fluids, a few sets of tires, and greasing the door hinges ;).
  9. rjdriver
    rjdriver Active Member
    406
    168
    Rhode Island
    Some sacrifices were made in the C to hold the weight down for maximum gas mileage, one of them being a sophisticated suspension system. Hence the more pronounced effects when going over bad pavement, squeaks and creaks among them. Mine is the same. Many of them seem to come from the area around the glove box and right side upper dash panels. I have wedged a few business cards and rubber gaskets into key spots to minimize the noise but have never been able to get rid of all of it.
    The rattle under the hood is of more concern and I would definitely have that checked. It could be simple or serious. The cracked plastic in the tail light assembly sounds unusual however. I wonder if the previous owner may have done something to cause that, and it didn't effect the bulbs until later.
    All rotors rust pretty quickly these days. Have seen new cars still on the dealer lot with seriously rusted rotors. As someone else mentioned, due to the regenerative braking system in hybrids, it doesn't get cleaned off as quickly in normal use. The upside of that is that you won't need brake pads as often. I just had a state inspection at 116,000 miles and was expecting to be told I needed new pads, or would before long, but it passed with flying colors. And they are the original pads.
    I think you have mainly just had some bad luck. Other than the squeaks and creaks, my 2012 C with similar mileage hasn't had the other problems you mentioned, and I live in the cold northeast also.
