Unknown noise from dash, somewhere behind steering area
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by chrism07924, May 10, 2005.
  1. chrism07924
    chrism07924 New Member
    79
    Bernardsville NJ
    If I drive slow and its quiet (windows up is better) I can hear what sounds like a muffled buzzing noise from somewhere inside the dash area, behind the steering wheel. I particularly hear it when I make sharp turns, usually left turns, but not always. Sometimes it happens as I'm slowing into a stop or just after the stop. The best way I can think to describe the sound (since buzzing isn't really it) is that it sounds like a fishing rod reel when you cast a line out slowly, and the spool is just unloading. Or, when you're reeling it in...like a gear winding. What is this?? I believe it may be related to the power steering being powered by the battery, and I'm hearing some kind of electrical device kick into action. It's pretty subtle, & if you had the radio on or had the window down, you'd most likely miss it. However, I have noticed it once or twice before but just ignored it. Now, just cruising around a parking lot looking for a space, I may have heard it about 3-4 times. Should I be concerned?
  2. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    Could it be the sound of the electric assist for the power steering. If so, you should hear it if you turn the steering wheel while stopped.
  3. chrism07924
    79
    Bernardsville NJ
    Hi Don, no, I specifically did that test and no sound. It seems to have a mind of its own, coming on a certain times for a couple seconds, usually when driving slowly and just before or after a turn. But it's happened approaching a stop at slow speeds and even after the stop. It's a clicking and winding like noise, like plastic gears spooling or something.
  4. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Is that the same sound that occurs if you pump the brakes alot?
    A whirring sound would be the electric steering wheel assist. It is an electric motor turning the steering wheel on demand from the torque sensor or parking assist (in Japan).
  5. tristansh
    tristansh New Member
    us
    2001 Prius
    did you ever figure out the cause of that buzzing noise? I am experiencing something very similar and I am pretty sure it is a defect.
