Unknown parts when doing oil change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ZWANG20, Sep 6, 2023.
  1. ZWANG20
    ZWANG20 New Member
    CA
    When I did oil change today, I found those two parts on the plastic board. This is 2010 Prius II with 180k miles. Please share if you have any idea.
    49,492
    could those be from the filter assembly? spin on or cartridge?
  3. ASRDogman
    ASRDogman Senior Member
    6,092
    3,273
    I believe that those are from the exhaust pipe to the manifold.
    Has the engine been changed? Or the exhaust?
    There are 2 springs with the bolts that hold the exhaust pipe to the manifold, with
    the gasket in between...
  4. ZWANG20
    ZWANG20 New Member
    CA
    the catalytic converter has been replaced once before.
    douglasjre likes this.
  5. ASRDogman
    6,092
    3,273
    Those must be the parts then.
  6. Tombukt2
    Tombukt2 Senior Member
    9,138
    1,586
    Durham NC
    I was going to say if your cat's not missing you said it's been changed those parts got caught up under the plastic fell out when you changed the oil
  7. ZWANG20
    ZWANG20 New Member
    CA
    the cat has been replaced one year ago due to a theft. yes they fell out when I changed the oil.
