Unscheduled Acceleration Poll
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Susan4ET, Mar 13, 2010.
  1. Brake Override
    3 vote(s)
    8.8%
  2. Brake Assist
    2 vote(s)
    5.9%
  3. Neutral or Reverse
    3 vote(s)
    8.8%
  4. Park
    2 vote(s)
    5.9%
  5. Power
    3 vote(s)
    8.8%
  6. None of the Above.
    31 vote(s)
    91.2%
Multiple votes are allowed.
  1. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Using your best judgement and understanding of these unscheduled acceleration incidents, Gilbert's simulations, and Toyota's simulations, did any of the following fail to work properly or would any have failed to work properly?
    1. Brake Override?
    2. Brake Assist?
    3. Neutral (or Reverse)?
    4. 'P' Park button?
    5. 'Power' button?
    6. None failed
    I'm not interested in anything technical such as whether there were error codes or wiring damage and the like. I'm interested in stopping the car safely. Further more this unscientific poll and by the nature of other cars involved in the simulations isn't limited to only Prius.
  2. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    I don't think anyone can make more than a wild assed guess at an answer. We just don't know for sure.
    - D
  3. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    Strange that during the simulations no one tried other systems involved to see if they worked or not. Seems like that would have been a huge plus factor for Toyota--if the other systems still worked normal?
    Even Gilbert in the ABC video told the reporter that the brakes were working but didn't elaborate specifically if there was Brake Assist? It sure didn't look like there was any Brake Override. Come to think of it I don't think that car was a Prius.
    Seriously, you'd think this would be something everyone would take seriously in the course of any simulation--that even if you've experienced an unscheduled acceleration all the other systems still work or some work and some don't or none work? Not knowing that much leaves me more concerned then the acceleration in and of itself!
    I thought people were more willing to stick their necks out in posts...but apparently not in silent polls. I don't feel as comfortable as I did and will stick to not exceeding 55 mph.
  4. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    If I could edit the poll question I would reword it, "Do you think Unscheduled Acceleration also causes these other System Failures:"
    It would be nice if anyone does select any of the 5 systems if you would explain why in the thread here or point to your reasons why elsewhere.
  5. hill
    8,640
    I had to check everything because if I could imagine one thing then I could probably imagine all those and more!
  6. don_chuwish
    823
    190
    Southern Oregon
    Ah well you're making the incorrect assumption that Gilbert and ABC were conducting "science" and "journalism" respectively.
    I have no worries about my car. Did 150 mile round trip this morning with cruise at 65-68 and was passed by 2 other Prii drivers who obviously weren't too concerned.
    - D
  7. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    I sincerely hope Toyota finds some system error, an actual error, which they can fix.
    If, as I suspect, the vast majority of reported UA problems have actually been incorrect floor mats, drivers confused by right and left feet while in reverse, and malicious fraud, how can Toyota ever get out of this mess? You can't fix your car owners, only your cars.
    I vow never to drive my Prius over 108 MPH. (the ECU won't let me) I tend to do 61 in a 55 zone.
    I have tried the Power, Neutral and Reverse methods to slow my Prius as practice, they all work. My only actuall UA was as a passenger in a Ford Aerostar, years ago.
  8. don_chuwish
    823
    190
    Southern Oregon
    I tend to agree with you on this Jimbo, tho if they did find and fix the problem the number of fake UA's would skyrocket prior to cars getting fixed. Nightmare no matter how it goes.
    - D
  9. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    I had a thought... If Toyota claims to have duplicated Gilbert's and their simulation of the "stuck accelerator" in their line and _also_ in n-number of other manufacturer vehicles with no error codes produced then why haven't these other manufacturers cars had their own share of real world stuck accelerators? Also, if the "stuck accelerator" is a real problem but can only be simulated by a resistance between two wires and a third wire connecting to 5 V and that this is so unlikely to actually occur with cracked insulation or damaged wires--especially since (I think I read) they have found no evidence of damaged wires, then doesn't this point to something inside an ECU (Electronic Control Unit)? I trust Toyota is looking elsewhere and won't shy away from possibly finding the problem inside an ECU?
  10. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    Susan, Gilbert did work with non-Prius Toyotas.
    There's a reason why folks like me won't answer the poll. We don't know. Right now, Hobbit and KBeck and BWilson4Web and maybe a couple of other folks on this forum are the only folks who can really give an intelligent answer to the poll.
    The only answer the rest of us can give is "What do you think, based on not knowing?" What this could do is give Toyota a picture of what its PR problems are, even among a generally sympathetic audience on PriusChat.
    What this could NOT do is give a good view of what the problems actually are.
    What I also think it cannot do is give you the advice you want--advice on how safe the Prius actually is.
    The best information I can find on that is material that BWilson4Web put up a few days ago, based on an analysis of actual fatalities in Priuses vs. other cars, with a link to the research. He concluded that Priuses are safer, based on statistics through 2007.
    Quote:
    We're pretty much sure this is just Fear Uncertainty and Doubt versus a real safety risk. For example, I looked at 2001-2007 Prius Fatalities and found our cars [Priuses] had half the national fatality rate. This is a hard fact that few news organizations have picked up.
    Endquote
    The only thing I can add to what BWilson says is this: The Great Toyota Unintended Accelleration scandal allegedly involves cars roughly 2000-present. As far as anyone has noticed, there is nothing about the Gen III (2010) Prius that makes it more subject to unintended accelleration than any of the other cars. Therefore, I find BWilson's research to reassure me, even if it doesn't have the stats for 2010's yet.
  11. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    You or someone didn't check Brake Assist. Is that because Brake Assist might be the one independent system that some ECU couldn't override and disable? If that is the case then all the Prius incidents could have come to a happy landing by proper application of the brakes.
  12. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    What other systems could you also have imagined when you say 'more'?
  13. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    I'm not being that complicated. My only real _assumption_ at this point is that possible so-called failures with the five systems listed above in the poll will all prove to be driver error induced and that UA like the 'tip of the iceberg'. I will also assume that once UA is solved and corrected the rest of the 'iceberg' will be forgotten and things will go back to 'normal' until something else raises the issue of driver error. Toyota likely will be able to prove that none of the five systems ever failed.
    BTW, since someone suggested it...are there other systems I have overlooked or is there some central ECU that could take-out (cause to fail) any or all of the five systems listed?
  14. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I only wish to submit, Susan, that you're trying to think about
    this *way* too hard.
    _H*
  15. bisco
    51,141
    you're in way over your head and mine too. i don't understand your poll or reason for it. it doesn't matter what anyone 'thinks'. statistically, you are driving one of the safest cars on the road. cast your fears away and go for a spin. or trade it in.:)
  16. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    How do you figure I'm in over my head, or you either? What don't you understand about the poll? The poll is just a different way to have a discussion on what people think about the issue overall. I wanted to see if I might have missed reading something significant. I read a news clip earlier today that Toyota didn't find anything wrong with the car near San Diego they examined along with another 2008 Prius. I find it all very fascinating--the technology and driver errors and people trying to pull off hoaxes. I even wear House, M.D.'s 'T' that says, "Everybody Lies". Some may think I'm 'over my head'. Some may think I'm 'paranoid'. A good friend, (who I think is paranoid) thinks I'm insane to be driving or riding in any Toyota, much like I feel about driving or riding on a motorcycle or riding a bicycle in mixed traffic. Toyota even mentions how Brake Override cuts the engine to idle. I wonder how the guy in San Diego was even able to burn-up his brakes if it was a hoax? Time to die? Time to wait!
  17. Sagitar
    Sagitar Junior Member
    59
    Ampthill
    I have no experience of "unscheduled accelleration" and nothing that I have read convinces me that it is a characteristic of the Prius that I own, so I cannot contribute to the poll.
  18. RoyThePriusGuy
    RoyThePriusGuy New Member
    186
    25
    phoenix
    Way over your head... that sure is an understatement. I've seen uncomprehensible and nonsensical polls here and other places - but this one gets top prize.
  19. Susan4ET
    Susan4ET Member
    429
    53
    Central Oregon
    That is of course your opinion. I would not accept top prize from you--maybe from a moderator or Toyoda. Is it possible that those of you who think I'm 'over my head' in this poll/discussion prefer to leave your heads buried in the sand? It is clear that the poll and this discussion in PriusChat was a bad idea in that there isn't one of you or myself that lacks confidence in the car?
    What the poll was trying to demonstrate was something that didn't require a poll here in any of the 2010 Gen III forums and likely has no place here in PriusChat. None of the five means to stop or help safely stop a runaway acceleration have ever failed. What has failed deliberately or by accident in every one of these incidents is the driver by not being familiar with the car they drove. Even those who maybe put their whole incident on as hoax demonstrate they don't know how to control the car in an emergency--else some or all of the five ways to stop the car would have failed too--and that I and some of you can only speculate has never happened.
    But again, this doesn't interest PriusChat. If a moderator would like to close this thread or even better delete it please do so. I will try to stick to physical problems that concern me on my Prius and pay no attention to others problems or speculate that driver training on hybrid/new technology cars is poor to none.
  20. kgall
    kgall Active Member
    984
    152
    Susan,
    The reason you are getting so much resistance is that this is a group of people who largely don't care about "what people think about the issue overall", at least when it comes to the decision about whether or not to drive/buy a Prius.
    When it comes to that issue, what they (including me) care about is the evidence of safety/dangerousness, which is why I previously referred you to the best evidence of THAT which I have seen--BWilson4Web's analysis of fatality statistics, which indicates that the Prius is safe.
    If you want the scoop on the Sudden Unintended Accelleration problem, most of us (again including me) have a lot more trust in the work diisplayed in other threads by BWilson, Hobbit, KBeck, and a few others--which so far is not conclusive--than in our own random "feelings" on the matter.
    "What people think about the issue overall" tells Toyota what its advertising/PR issue is--it does not tell me (or you) how safe my car is.
    And welcome to PC!
