Unstable battery discharge power
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Guize Yin, Nov 23, 2022.
  1. Guize Yin
    Guize Yin Junior Member
    I have a 2006 prius with 107k miles and in 2021 the HV battery was replaced at 91k miles, I was reading the data with the car scanner and noticed that the HV battery discharge power was erratic and I'm sure I was Full throttle.
    52,385
    new oem battery, or aftermarket or rebuilt?
  3. Guize Yin
    I think it's a rebuilt
    52,385
    that might be the problem
  5. mr_guy_mann
    mr_guy_mann Senior Member
    4,087
    1,997
    NJ-USA
    What symptoms are you having? I haven't used "power" in the data for diagnostics so can't really say if what you show is normal. I usually just look at HV battery block voltages, State Of Charge, and amps while driving the car.
  6. Guize Yin
    It doesn't usually have symptoms, it's just something I found out by accident, and it's not working its full horsepower.
    #6 Guize Yin, Nov 24, 2022
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Rebuilds are a hope & pray most have no warranty and even if they do good luck with that. There using the same age modules you already have in your car they have just not failed yet.
  8. mr_guy_mann
    4,087
    1,997
    NJ-USA
    So, it might be that the car is working as the engineers designed it. I mean if the car drives ok, no codes, then is there really anything wrong?
    I'm not an engineer so I can only guess that maybe you don't want/need full electric drive under most circumstances. (might exceed the torque limits of the transmission?).
