Unsure if Battery is Working
Discussion in 'Gen 2 Prius Technical Discussion' started by dlobmwm3, Aug 3, 2010.
  1. dlobmwm3
    dlobmwm3 New Member
    North Carolina
    I just purchased a 2005 Prius certified with 57k miles. I also purchased the Platinum wrap around warranty. My question to you all is, what does a normal battery meter look like. My battery has mostly stayed purple in the last 2 days that I've had it. One time it turned all green but stopped 1 bar short of touching to +/- ontop of the picture for the battery. As you can see the bar is missing 3 bars. Is this normal or should I take it in to get it looked at?
  2. BAllanJ
    BAllanJ Active Member
    667
    78
    Kingston Ontario
    Normal... i've only seen all green once... the car seems to aim for 7 bars... blue. I think the car does this so the battery lasts a long time and so you always have some room to store some energy when you hit the brakes.
  3. BAllanJ
    667
    78
    Kingston Ontario
    Oh... and welcome
  4. dlobmwm3
    dlobmwm3 New Member
    North Carolina
    Thanks. But I've never seen the 3 blue bars either but maybe 1 time. How do you get them to display more?
  5. Patrick Wong
    18,200
    6,482
    Very normal.
    You really don't have to worry about the battery state-of-charge. You'll probably find that the battery SOC will be higher in seasons when ambient temp is not so high and you are using the air conditioning less.
    Nevertheless in the summer it is important to maintain a reasonable cabin temp, for your comfort as well as for the traction battery's comfort (which obtains air inflow via the duct located near the right side rear passenger seatback.)
  6. dlobmwm3
    dlobmwm3 New Member
    North Carolina
    I managed to get the bars to turn green but one bar short by I guess what you call gliding?
  7. MJFrog
    MJFrog Active Member
    780
    266
    NE Oklahoma
    2018 Nissan LEAF
    No. True gliding AVOIDS any regen into the batteries as much as possible. Regen is good when you are recovering energy that would have been wasted anyway (e.g. heavy traffic you couldn't otherwise avoid, or sudden red light, etc.), but coasting (foot off the pedal and regenning) or light braking JUST to add charge to the battery is not fuel efficient.
    Unless you're driving a PHEV, the only way to get electricity into the battery is to use gasoline to run the ICE. This involves multiple conversion losses that bring down FE. Gas>ICE>electric motor>electricity>chemical battery>electricity>electric motor>wheels is always less efficient than gas>ICE>wheels.
    A hybrid is more efficient than a pure gas/diesel vehicle because it can recover energy that would have been wasted otherwise.
    Check out the fuel economy threads and forums.
  8. richard schumacher
    7,663
    1,041
    United States
    Turn on the "Energy" display. When "gliding" there are no arrows into or out of the electric motor shown on the display.
  9. vertex
    vertex Active Member
    672
    143
    new york
    2018 Prius Prime
    I've had all the bars green after a longish down hill run. Then the ICE turns on to DISCHARGE the battery, don't want to overcharge it.
  10. SupratoPrius
    SupratoPrius New Member
    H-town
    Thank goodness... I was wondering the same thing with an 04 Prius I just bought! :)
  11. bisco
    50,052
    nevertheless, unless you're in stop and go/idling traffic all the time, you should see 4-5-6 blue bars on average.
  12. uart
    uart Senior Member
    4,215
    1,202
    Australia
    Yep, but did anyone else notice that although the OP said his SOC indicator had "mostly stayed purple" the picture he posted shows a perfectly healthy 6 blue bar SOC?
    He also says that "One time it turned all green" but never mentions "blue" (or the actual number of bars) at any time. Is anyone else uncertain as to whether or not the OP is simply confusing purple and blue (as in, seeing blue but calling it purple)?
  13. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    This is a very common misconception for newbies.
    First, the battery display shows from about 30% charge (all bars gone) to about 80% charge (all bars green).
    The system doesn't want to -fully- charge or -fully- discharge the battery so the charge level is controlled very carefully.
    Second, if your engine starts whenever called for, your battery is fine. The "traction battery" is the only thing that starts the engine.
    Third, as mentioned above, the system tries to keep the charge level at three to four bars from the top. This is to ensure there is "head room" in case regen. energy is available for storage, yet still have enough energy to help with acceleration.
    Fourth, you -may- see all green from time to time, but it's rare unless you are descending a very long hill. If you are using A/C cooling a lot, you -may- see purple bars (two or one) from time to time.
    Finally, as they say "DON'T PANIC!". There is nothing you can do better than the system re controlling battery charge. The HSD WILL protect the battery. If the battery IS in trouble, you WILL get lights on the dash telling you it needs service!
    The only thing -YOU- have to do is not run out of gasoline. If you do and keep driving, -then- you could force a marginal battery toward death. Don't worry if this has happened in the past. If it did the battery would probably have been replaced.
