Unusual huge swing in fuel economy
Discussion in 'Gen 2 Prius Fuel Economy' started by hybridmel, Dec 17, 2009.
  1. hybridmel
    hybridmel Junior Member
    36
    Okay, so I expected that when cold weather hit that my fuel mileage would drop.
    However, imagine my surprise and shock, when it decreases by 75%!
    Normally, I fill up every 4-6 weeks, just depending on how much I drive. Well, the last 2 weeks, it is taking about a week to go through a whole tank. And, I am not driving hardly at all. I did not do a reset to see how many miles per tank. And, I am not keeping an eye on the actual mpg's. All I know is a tank is only lasting me a week.
    That seems like an awfully big drop, unusual I'd say.
    The guy at the dealership where I get it serviced said I needed to pump my gas more slowly, because it thinks there is more gas in there than there really is. But, I checked my receipts, and I am putting in pretty much the same number of gallons of gas as I always have before. So, I don't see how that could be true.
    Any ideas?
  2. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Without specifics on miles and number of gallons pumped I don't think anyone can really help you. Maybe you've been driving in B mode on accident?
  3. sfvb
    sfvb New Member
    17
    Northern IL
    75%? I hope that's an exaggeration. The following are examples of a 75% decrease:
    was getting 40, now getting 10
    was getting 50, now getting 12.5
    was getting 60, now getting 15
    was getting 70, now getting 17.5
  4. hybridmel
    36
    Well.......normally it takes at least 4 weeks to go through a tank of gas. Now, it is taking one week. To me, that is 75%.
    No difference in driving patterns or anything like that. Is my math off?
  5. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    There is no math involved yet. We need more numbers. In one week you could have driven 200 more miles than the previous or maybe you pumped 2 gallons less.
    Please go fill up the fuel tank and reset your trip meter and drive till you get to the last two bars on your fuel gauge. Refill the tank and record the gallons pumped and the # of miles driven on that tank then post back up.
  6. ksstathead
    ksstathead Active Member
    1,244
    244
    Kansas
    You should notice your instantaneous mpg being 10ish instead of 45-55ish with a 75% drop, and their should be a sputtering engine and smoke billowing all around perhaps.
    Edit your info to show the year of your Prius so we know what generation it is.
  7. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    Perhaps the OP could shed some light on why his/her avatar says...
    "other non-hybrid," :confused:
    Is this even a Prius related matter?
    Even so, sounds like somebody with a handy-dandy siphon.
    Do you always lock your car... every single time?
  8. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Start a log where you note your tank mileage and the amount of gas used to refill the tank (353 miles, 8.52 gallons for example). Track this over time. You, currently, aren't measuring fuel economy, instead you are measuring your fill-up interval.
    The two aren't interchangable.
