Unusual problem w/ Mariner Hybrid!
Discussion in 'Ford/Lincoln Hybrids and EVs' started by Sokool, May 29, 2008.
  1. Sokool
    Sokool Steve S
    Fort Lauderdale, FLA
    I was driving my 2006 Mariner Hybrid when all of a sudden a message came on the dash "safely pull over". I did and the car turned off and would not start. I waited about 5-10 min and it restarted. It happend a week later but this time it didn't start until the next day. Does anybody have any ideas? The local Ford dealership Service Manager had no idea. Never heard of it before. ANY ideas would be appreciated. Thank you.
  2. EJFB1029
    EJFB1029 New Member
    4,726
    206
    Corpus Christi, Republic of Texas
    Wish I could help you there, but doesn't that kind of fit the saying:
    Found On Road Dead
    Had to say it, sorry. :D
  3. sendconroymail
    sendconroymail One Mean SOB
    256
    You shouldn't have put Mercury on your list! :D
  4. M. Oiseau
    M. Oiseau 6sigma this
    270
    Tulsa, OK
    Um. Try a different dealership?
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Mr. Goodwrench would have said, "It's supposed to do that."
  6. MO Dale
    MO Dale Junior Member
    43
    Jefferson City, MO
    Out of curiosity I ran a search and found an incident of the message over on hybridcars.org with an '08 Escape. Don't know if it's the same, but check it out.
    Please Pull Over Safely! | Hybrid Cars
  7. galaxee
    galaxee mostly benevolent
    9,810
    464
    MD
    c'mon guys, we're talking to a fellow hybrid owner here. let's back off on the snark, even though the brand is different.
    you need to find a local ford/mercury mechanic who can do diagnostic work. there's probably some trouble codes being spit out by your various ecu's that will help to identify the issue, and you need someone who can follow this trail of clues to the scene of the crime so to speak.
    good luck!
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Agreed. Galaxee has the best (and only) suggestion. Look at the codes. If the dealer can't help you, find one that will.
    Tom
  9. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    I just tried to help diagnose yet another Escape that was doing
    the same thing, according to its owner, and there was apparently
    some indication of high temp involved. I drove it a little and
    it didn't happen for me; the car showed no codes but I couldn't
    get the Ford enhanced stuff working so there may have been some
    ECU-specific history codes I couldn't see. Everything seemed
    normal, the A/C worked fine [which is used as part of the battery
    cooling regime, so it needs to be functional], and all the fluids
    were at proper levels. A bit of a headscratcher. Perhaps it's
    just endemic to the FEH/MMH or there might be a TSB out or
    whatever.
    _H*
