Up Down Buttons
Discussion in 'Gen 2 Prius Main Forum' started by DBM, Apr 29, 2005.
  1. DBM
    DBM New Member
    36
    SF Bay Area
    Any idea what's the logic (or lack thereof) of having the channel and temperature buttons on the steering wheel operate in opposite direction?
    DOWN - channel - UP
    UP - temperature - DOWN
  2. flareak
    flareak Fleet Captain
    1,016
    St Louis, MO
    HuuuuhHHH??? they don't operate in the opposite direction on mine
  3. DBM
    DBM New Member
    36
    SF Bay Area
    They don't operate in opposite direction than the label on them. But they are placed so they operate in opposite direction to each other. In other words, the left channel button changes the channel down while the left temperature button changes the temperature up.
  4. Tideland Prius
    16,127
    Well, the channel button is keep in line with the SEEK TRACK button on the dash.
    However, with the temperature button, the left is slightly higher than the right, hence up (left) or temp up and the down (right) button for temp down
  5. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    yup, in other words
    UP
    -----Temperature-----
    ------------------------DOWN
  6. altaskier
    altaskier New Member
    157
    Long Island, New York
    <div class='quotetop'>QUOTE(DBM\";p=\"85623)</div>
    The answer is obvious. The designer of one of the buttons is from Australia, where everything is upside down.
  7. mtc1234
    mtc1234 New Member
    39
    Laurel, MD
    Only adjust the temperature when turning a corner.
  8. NiMHpwr
    NiMHpwr New Member
    70
    San Jose, CA
    I think part of why it was done like this to keep symmetry to the buttons on the right side of the steering wheel. The positioning seem completely intuitive to me.
  9. flareak
    1,016
    St Louis, MO
    oh i see what you mean now. but at least the temp isn't horizontal... being diagonal it makes sense that the temp up button should be higher. think about it: if you switched the temperature buttons around, it feels like you are moving your thumb down to turn the temperature up
