Update: J2534 Bus Analysis Tool (and specs!)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MrPete, Aug 24, 2023.
Tags:
  1. MrPete
    MrPete Active Member
    424
    172
    Colorado, USA
    I spent a few round-toit's digging into the details on the J2534 bus, its specs, and the free Bus Analysis Tool. Here's what I learned. (NOTE: I've not yet used any of these tools ;) )
    There are two versions of the tool, for two different versions of the J2534 spec
    Does it matter which version? I think it may make a BIG difference. This could explain many incompatibilities. NOTE: 2004-12 was the first rev since 2002-02 version. And 2015-10 was first since 2004-12!
    While SAE charges over $150 for a copy of the specs, there's no charge for a preview of the Table of Contents. That told me much of what I needed!
    • The 2004-12 version standardized many things, not least the ability to "Pass-Thru" various communications.
      • More importantly, it standardized support for seven communication protocols (ISO 9141, ISO 14230-4 (KWP2000), SAE J1850 41.6 kbps PWM, SAE J1850 10.4 kbps VPW, CAN, ISO 15765-4 CAN, SAE J2610 DaimlerCHrysler SCI)
      • And it standardized Simul-cast on multiple protocols
    • The 2015-10 version made significant improvements
      • Support for ISO 15765 both full and half duplex; individual per-channel timing/control
      • Specs refined to handle ambiguities, error handling and more.
      • Support for combined/same-link CAN + ISO 15765
      • Pass-Thru Device Discovery added (and specific support for wireless/BT devices)
      • Support for larger messages (original:4-4101 bytes; 4128 for J1850VPW; not sure how much more the newer spec supports, but I am pretty sure it's needed for various reprogramming/update tasks.)
    Since the 2015-10 revision, of course there's been an ongoing series of further refinements.
    AFAIK, 2015-10 is now known as J2534-2 while 2004-12 is J2534-1.
    I'm hoping the above bit of research may help our community untangle why some cables and dongles work well, and others don't.
  2. ChapmanF
    15,529
    You could probably color me surprised if any of the J2534 devices we typically talk about on here even claim or try to support a spec from the last decade.
    Possibly the pro-level Drew Tech ones (or whatever the name of that outfit is now).
    Tombukt2 likes this.
  3. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    I believe several of the pins on the OBDII interface are manufacturer prerogative. What you really need to handle all the manufacturers combined is what I believe is called in electronics a big MUX, lines are assigned depending on manufacturer. Some are fixed, and some manufacturers are shifting to using the J whatever # standard for diagnostics.
    My VXDiag Multi Diag is one device that handles quite a few manufacturers based on a license I have to pay per manufacture, (unless you buy a package with all of them):
    VXDIAG Multi Diag Serie
  4. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
  5. MrPete
    424
    172
    Colorado, USA
    What did you attach? It's a bad link :(
