UPDATE: Mystery Warning light P3140
Discussion in 'Generation 1 Prius Discussion' started by lmarcucci, Jun 17, 2014.
  1. lmarcucci
    lmarcucci Junior Member
    53
    hershey
    Hi everyone,
    I received my Mini VCI and sure enough the code was P3140 off of the hybrid ECU. My little bluetooth OBD2 scanner and torque just wasn't enough.
    I tried removing and reinstalling the orange safety lock on the battery, and I even tried pulling one off of my other running(with no warning lights or CELs) GEN1 prius. It still gave me the warning light.
    The funny thing is that when I tried to clear the code with Techstream, my prius behaved the same way as when i tried to clear it with torque. It kicked it off for a second, then the engine died, and a check engine light came on(the CEL went off when I restarted the car).
    I noticed that the inverter coolant hose routing was basically reversed. Would that cause this? I'm going to fix it tomorrow. I had my auto tech friend do this swap, this time. He attempted to do it without labeling anything besides major things.
    I compared all the other inverter wiring with other perfectly running GEN1 and another working inverter I had laying around and I sat it on the ground in between the cars. There really aren't that many wirings going to it. Nothing that looks like it could have been mis-plugged.
    Do you guys have any ideas? Research said to check the inverter casing, but everything looked untouched.
  2. bwilson4web
    16,380
    We never figured it out. What pissed me off is I could not characterize the signal on a working Prius. It remains a mystery.
  3. lmarcucci
    53
    hershey
    LOL. great. I'm totally F'd then. It has to be something electrical since it detects the error upon putting the key in the accessory position after leaving the 12V battery disconnected(Clearing the codes).
    I was doing more research and people said to check for any pinched or damaged wires around the inverter. And to also check the inverter cover sensor. I have two working inverters(one from my other running gen1 and the other from a working gen1 inverter). Someone also said to check the two pin wire connected to the HV battery near the orange service plug. So, i'll check on that tomorrow and post my results.
  4. lmarcucci
    53
    hershey
    TAHHHH DOHHHH!!!
    So, if anyone ever has the P3140 problem, check your inverter terminal covers!
    The terminal cover that goes over those terminals pictured above(I think those go to MG1(Don't quote me on that)), has a connector on it that goes into that white connector on the lower left hand side of the terminal case. The connector on the cover literally has a jumper in it, and all the white connector does is close a circuit that senses whether or not the cover is over the terminal case securely. If the cover is not on, not on correctly, or if the pins on the white connector pins are bent(like mine pictured in the top photo), you will get a P3140. You will get a triangle with no CEL. The only way to pull the code is to get a mVCI and techstream. The ABS light may flash as well. By the way, this also will happen with the terminal cover in the lower driver side of the inverter. You will get a P3140 and ABS light may flash as well. Just like the terminal shown above. This has been tested on two different priuses. CHECK YOUR TERMINAL COVERS PEOPLE!
    P.S. I haven't removed the actual large silver inverter cover to check if it also has a sensor on it. I will do that tomorrow.
    Itsmeonprius and bwilson4web like this.
  5. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    I'm getting the P3140 with 350 on my 2003. I've had the terminal cover off twice and all looks good with that connection. I can clear the code but it comes right back when I turn the key. What should be my next step?
  6. Itsmeonprius
    Itsmeonprius Member
    119
    56
    Scotland
    2001 Prius
    Active
    Yeah both covers have that connector. Some sort of safety interlock.
  7. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    The inverter cover itself has one too?
  8. mroberds
    mroberds Member
    143
    59
    2001 Prius
    I didn't see one when I took my inverter cover off - the big one that's about a foot (30 cm) on a side, aluminum-colored, and has the "Toyota Hybrid System" sticker on it.
    There is one on both of the smaller covers for the MG1 and MG2 cables. Imarcucci posted a picture of the one that's on the back of the inverter - the one that's about 4 inches (10 cm) on a side and black. The one that's on the driver's side of the inverter - the one that's kind of oval shaped - has one too.
    You can also get P3140 if the microswitch for the service plug isn't closed. This can be because the service plug isn't installed correctly, or you forgot to flip the service plug handle up, or if the tab on the side of the service plug that moves the microswitch lever is bent or broken. (Take a flashlight with you when inspecting this; it's in a dim corner of the trunk.)
    I recently got a P3140 and all was OK with the terminal covers, and the service plug microswitch appeared to be working. However, the contacts in the microswitch had apparently got crudded up after many years of low-current switching service - it would either measure open circuit with the microswitch lever pushed down, or a relatively high resistance value (20 to 40 ohms) with the microswitch lever pushed down, where it should be less than an ohm. I took the microswitch off of the car and tried different things, but what seemed to help the most was blowing in it. :) More info in this post: Chasing info code 123 *without* P3000? Or do I need a better scan tool? | PriusChat
    I hope this helps!
    Brian in Tucson and WHCSC like this.
  9. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    Great info! Thanks!
    mroberds likes this.
  10. Brando714
    Brando714 Member
    101
    16
    Anaheim, CA
    would it be safe to work on the inverter cover once I unplug the 12V and Hybrid battery pack?
  11. ChapmanF
    18,569
    It is, after you have waited long enough since unplugging the traction battery service plug, for the charge on the capacitors inside the inverter to bleed off.
    I don't remember off the top of my head how long that is. It's in the repair manual (more info).
  12. Brando714
    Brando714 Member
    101
    16
    Anaheim, CA
    ok thank you
  13. Duddy03
    Duddy03 Junior Member
    22
    Crossville, TN
    2018 Prius Prime
    Hi. I am jumping into this topic, late in the game. I have an '04 Prius. I installed the FOB in the slot. Something didn't seem right. I couldn't turn off the engine, remove the FOB, or open the trunk. I had to manually open the truck, remove the negative post from the 12 V battery, and remove the orange plastic plug from the traction battery. A code P3140 was set and an ask-for-fee Toyota mechanic said it was a faulty solenoid behind the dash. A pin is supposed to retract when the engine is turned off so that the FOB can be removed. Apparently, this solenoid sometimes fails and needs to be replaced. My solution was to put a piece of masking tape over the slot. The code description is "Interlock Switch Operation." The odd thing, is that your discussion reminds me that there is a strange noise from the inverter cooling fan after turning off the engine. The Toyota dealer replaced the inverter pump last year and there may be a coolant air pocket in the reservoir. Or, from your discussion, above, there may be a harness or electrical connection issue. Suggestions?
  14. ChapmanF
    18,569
    You "had to" remove the orange plug from the traction battery?
    What convinced you that you had to?
  15. ronlewis
    ronlewis Active Member
    1,042
    204
    texas
    2001 Prius
    I don't recall the Gen1 inverters I've messed with having that tab on the cable cover. I have one here, but the cover is off (not sure where I put it). The slot is there in the box, but it has what looks like a plug in it. Can't tell if your pic shows the same. I'll post a pic.
  16. Duddy03
    22
    Crossville, TN
    2018 Prius Prime
    The failed solenoid for the FOB caused the code P3140 - a condition unrelated to the inverter issue discussed by the rest of you guys. I could not remove the FOB, turn off the engine, or put the car in drive or reverse. Killing all battery power unlocked the FOB, turned the engine off, and allowed me to open the trunk. Apparently, a workable solution is to never insert the FOB in the slot; just keep the FOB in your pocket. Still, has anyone removed and replaced the solenoid in the dash?
  17. ChapmanF
    18,569
    P3140 is definitely about the safety interlock circuit protecting the high voltage system, which includes one set of contacts verifying the battery service plug is in place, and two sets verifying the inverter cable covers are in place, and has nothing to do with the key fob or its slot.
    That's not to say it wouldn't make an interesting story to hear how someone became convinced the key slot caused a P3140. There might be a lot of things to learn from that story—things about tricky inferences, say, more than things about P3140.
    Brian1954 likes this.
  18. dolj
    dolj Senior Member
    8,563
    4,350
    Wellington, New Zealand
    Why are you 'jumping into this' Gen 1 thread about a problem on Gen 2?
    The symptoms you list are consistent with a failing/failed combination meter (CM). There are plenty of threads about that in the Gen 2 forums. Use the 'Advanced Search' option to search just the Gen 2 forums.
