Updated intake manifold
Discussion in 'Gen 3 Prius Technical Discussion' started by yeldogt, Aug 4, 2018.
  1. yeldogt
    yeldogt Active Member
    810
    313
    NE
    I believe the Gen 3's got a modified intake at some point -- I'm I correct? If so when did this occur and what was the modification ?
  2. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Somewhere around 2012 and all they did was reduce its volume ;).
    It does not help te cold start knock symptoms :(.
    But that’s the change(y).
    51,155
    pointless.
    Raytheeagle likes this.
  4. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    At least they put their effort into relocating the egr cooler inlet downstream of the cat for the Gen4;).
    Hopefully that effort wasn’t pointless (y).
  5. yeldogt
    810
    313
    NE
    what was the point of the reduced volume ?
    I was surprised how much junk was in the intake -- mine was basically not working .. only #2 had a bit open.
  6. Raytheeagle
    11,263
    15,512
    2019 Prius Prime
    My speculation is reduced volume with the same air flow leads to less residence time or less ability for the egr return material to collect;).
  7. ReadyToRoll
    ReadyToRoll Junior Member
    34
    South Carolina
    As of 2021, my dealer parts guy says there are now 4 versions of the intake manifold. Mine still being the original first version for 2010, is there any reason to upgrade to version 4? I have the intake off and cleaned but not sure if it is worth $ to replace. He mentioned something about plastic pcs coming loose inside the intake in older versions??
    I would only consider it if the upgrade reduced egr clogging issues or general engine performance improvement. Physically mine seems to be in good shape, at least what I can see of it internally.
    Thanks for any reply.
