Updates to Navigation system?
Discussion in 'Gen 2 Prius Technical Discussion' started by Mary Lou In Ohio, Aug 30, 2006.
  1. Mary Lou In Ohio
    Mary Lou In Ohio Junior Member
    The Villages, FL
    I was wondering if there have been any recent updates to the navigation system? My Prius is an '05. And, if so, what is the cost?
    Thanks,
    Mary Lou
  2. cairo94507
    cairo94507 Active Member
    923
    36
    Auburn, CA, USA
    <div class='quotetop'>QUOTE(Mary Lou In Ohio @ Aug 30 2006, 06:49 AM) [snapback]311517[/snapback]</div>
    The disk in my '05 is version 4.2; version 5.1 is current disk available; the next nav upgrade is due to be released in October and is going to be a version 6. The price I was quoted was around $225.00 just for the disk, install it yourself.
  3. nyprius
    nyprius Member
    385
    24
    Saratoga Springs, NY
    <div class='quotetop'>QUOTE(cairo94507 @ Aug 31 2006, 09:08 AM) [snapback]312098[/snapback]</div>
    I understand the 05 and 06 nav systems are different. Do you know if the upgrade you mentioned will work in the 05? Also, will it improve the graphics of the 05 nav system, the way the 06 graphics were improved?
    thanks!
  4. Sarge
    Sarge Senior Member
    1,301
    758
    Milton, Ontario, Canada
    2023 Prius Prime
    XSE Premium
    <div class='quotetop'>QUOTE(nyprius @ Aug 31 2006, 12:41 PM) [snapback]312213[/snapback]</div>
    The resolution of the screen is a function of the hardware display itself, not the disc. So upgrading the disc will not change the look at all.
    My understanding is that there are two versions of the 2006 data disc; one for the "low resolution" display of the 04/05 nav system and another for the "high res" version found on 06.
    Kevin
  5. nyprius
    nyprius Member
    385
    24
    <div class='quotetop'>QUOTE(Sarge @ Aug 31 2006, 12:56 PM) [snapback]312225[/snapback]</div>
    Thanks!
