Updating the SATNAV on a 2011 Gen 3 Prius
Discussion in 'Gen 3 Prius Technical Discussion' started by Christopher Lynch, Feb 18, 2019.
  1. Christopher Lynch
    Christopher Lynch Junior Member
    40
    Pembury
    I am encountering an increasing frequency where my SATNAV is out of date,, and not recognising relatively new routes etc.
    Can I update the SATNAV data without paying Toyota's expensive rate; for free perhaps?
    I assume this 'data update' (Maps/POI's etc) is achieved by accessing an SD card?
    Is that SD card easy to both find and update using my Laptop??
    I look forward to receiving any good advice available out there.
    Many thanks for your time.
    Regards
    CJL
  2. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Identify the satnav model. Or show me a picture of the unit
    52,386
    it's proprietary toyota software. nothing you can update on your own
  4. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Yes, but there are cheaper alternative to paying toyota 120 euro / gbp
  5. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …just one more reason to use google maps (it's always up to date and requires no expensive upgrades!) :rolleyes:
  6. ChapmanF
    18,537
    In answer to the question, if you've got the 7 inch LCD display nav unit that was used in 2010-11 with the CD changer behind the display, the slot for the map DVD is behind there too.
    Starting with 2012, the Denso 7" unit has a hard drive and is updated at the dealer using a USB stick, whereas the Entune units with the smaller display and visible CD slot use an SD card.
  7. bisco
    52,386
    agreed
  8. Christopher Lynch
    40
    Pembury
    Thanks Guys.
    I'll persevere, and of course I can always use 'existing close by locations' and wing it from there etc.
    Thanks again.
  9. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
  10. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    If you guys and girls need any maps, let me know
    I do map updates, we only need to figure out what satnav you have
    Most units built after 2012 are being updated via USB + activation code
  11. hwoodall1
    hwoodall1 Junior Member
    Pittsburgh, PA
    I have a 2014 Four with 7” JBL 8 Speaker nav. How much?
    Thanks.
  12. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Can you take a picture, please?
