Upgrade / Replace Prius Seats? Desperate!!
Discussion in 'Gen 3 Prius Main Forum' started by tart_green, Feb 25, 2017.
  1. tart_green
    tart_green Junior Member
    35
    In the interwebs
    I have a 2011 Prius and work for a living in the car.
    I am in the car driving 8 hours a day. I LOVE the car, but the seats are really lacking in comfort and back support. After driving each day my back is incredibly sore. It is a manual seat, not power.
    Is it possible to UPGRADE to a newer model prius seat (from maybe a 2015?) with more comfort and back support?
    I'm not interested in adding pillows, I work out this car and I need a permanent solution. I will pay any price to keep this car and have a better seat.
    Any thoughts?
  2. CNYhybrid
    CNYhybrid Member
    158
    83
    Liverpool, New York
    I have the 2011 Prius Four and I find the leather seats quite comfortable.
  3. tart_green
    35
    In the interwebs
    OK, I'm glad, but it's killing my back.
    52,346
    there's no quick fix, but there are threads here from people who have put in power camry seats, volvo seats and etc.
    and also who have had the existing seat reupholstered. all the best!(y)
    CNYhybrid likes this.
  5. Mendel Leisk
    41,856
    That's the problem. I doubt any seat will help. You need to reduce that somehow.
  6. bisco
    52,346
    run behind the car?
  7. Mendel Leisk
    41,856
    I do not know, break your day, try to vary your duties, look for another line of work? I'm assuming this is work related.
    I used to be pushing a mouse around and keyboarding, eight-plus hours a day, hit the wall, went at diversifying my work from a lot of different angles.
  8. bisco
    52,346
    might be easier to trade cars.
  9. tonycd
    tonycd Member
    84
    56
    I think these posts aren't trying very hard to be helpful, and OP has a right to be peeved with them.
    OP, I'd consider trying to find a leather or Softex seat from a junked high-line Prius of this generation. Those seats have power-adjustable lumbar support, a seat bottom adjustment for angle as well as height, and have been reported to be much better for all-day comfort. It ought to be a bolt-in replacement if you get the whole seat; if it wasn't, they wouldn't be able to build both versions on the same assembly line.
  10. NavyLCDR
    NavyLCDR Active Member
    202
    127
    Lebanon, OR
    2024 Prius
    XLE AWD-e
  11. Mendel Leisk
    41,856
    @tart_green If you haven't already, I would check with a doctor too: a back injury could underlying your problems.
  12. bisco
    52,346
    hopefully the o/p has a sense of humor.
  13. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Try this: Remove the headrest. Rotate 180 degrees, and put it back in, so that it points backwards. It helped me a lot.
    MexicanChip likes this.
  14. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    I suspect the seats in every Prius of close model years are the same framewise. THAT is the problem. Changing the seat cover isn't going to solve anything.
    If it were me, I'd try the Lexus version of the GIII Prius. You might find a used one for a reasonable price.
    m.wynn likes this.
  15. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    I think David may be on to a possible good solution here. The CT 200 seats are absolutely Lexus-like, at least to my 5'9'' proportions. The problem may be that the CT's body is based on the Matrix and not the Prius. Wouldn't be surprised if modification were needed with regard to mounting. Another thought, which again pertains to my size, is that the Gen 2 driver's seat is far more comfortable and ergonomic than Gen 3. It actually has SOME lumbar built in. Again, cross-compatilbilty is the question. Unfortunately no quick and easy solution, but certainly worth investigating. I personally find the Gen 3 front seats to be laughable with regard to comfort.
  16. Rebound
    3,996
    2,645
    Portland, OR
    Try flipping the headrest. Takes 15 seconds.
  17. dmeans2anend
    dmeans2anend Junior Member
    usa
    I
    I totally agree that the Prius bucket seats are the most uncomfortable car seats ever made!!!!
    I'm very active ,athletic, and petite but get extremely sore back when I drive for an hour or more in my 2010 Prius.
    Since I'm tiny, the dip in the bucket seat really does a wringer on my back.
    I've recently made my own modification to the seat and it seems to help a lot with no more back pains but I do have to make adjustments regularly which is an inconvenient but well worth it just to be pain free.
    First, I bought the combo PharMeDoc wedge cushion seat and back support cushion on Ebay for only $23 with free shipping.
    Secondly, the 3" wedge cushion wasn't quite enough to take the dip out of the bucket seat where my hip would sink down into so I simply emptied a large bag of popcorn kernels in a large gallon freezer ziplock bag and tuck it under the wedge cushion to elevate me even more so that when I'm seated, my hip is level with me knees and there is no more strain on my back!
    This modification seems to have done the trick to relieving the stress on my lower back.
    The only con is that I constantly have to make minor adjustments to the bag of popcorn kernels so it doesn't slide under the cushion.
    My next change is probably to find a pillow cover for the ziplock bag of popcorn kernels so it doesn't slide around under the wedge cushion.
    CR94, edspecR and bisco like this.
  18. BZzap!
    BZzap! Senior Member
    1,607
    878
    If you aren't a devout P.E.T.A. advocate, I would install genuine sheepskin seat covers on your seats. They add about 1/2 to 1" inch of conformal padding that significantly improves the comfort level of the Prius seats. That's the first thing I do after buying a new car.
    Mikes Canvas: Sheepskin Seat Covers
  19. dmeans2anend
    usa
    I
    Good to know. Thank you. Seems like a wonderful option in the winter but doesn't it get way too warm in the summer especially if you are in a hot climate zone?
  20. BZzap!
    1,607
    878
    Actually these covers a very comfortable in the hot summer. They are very breathable and prevent sweating. I have never found any better solution for seat comfort ... summer or winter.
