Upgraded to Aftermarket HU, trying to get Trip/Ac to work again.
Discussion in 'Prius v Audio and Electronics' started by Mudko3, Feb 17, 2021.
  1. Mudko3
    Mudko3 New Member
    VA
    2014 Prius v wagon
    Hi all
    2014 prius v three non JBL , NAV
    I upgraded my headunit and got everything to work minus the right side of my steering wheel controls (AC/ Trip) to work. The only thing ive been able to find is that pin 23 needs to be grounded. Im not exactly sure which # plug that forum was refering to as it is dead currently.
    Anyone have ideas?
  2. Kiwibird
    Kiwibird Junior Member
    55
    Sydney
    i-Tech
    Hi Mudko3. Did u fix the steering control problem? I have the same issue, connected the resistor to the pin 9 and 10 white and pink and me me tioned in another thread Still no luck....
    See pdf attachment page 4 n 5
  3. Mudko3
    Mudko3 New Member
    VA
    2014 Prius v wagon
    Hiya I was able to solve it. I had to ground out a wire on the plug.
    I believe it was connecter 35 and wire 23 that needed to be grounded
  4. Mudko3
    Mudko3 New Member
    VA
    2014 Prius v wagon
    The first picture I posted highlights the back up camera. Plug 35 is the one on the left. Then the following schematic is the indepth
  5. Kiwibird
    55
    Sydney
    i-Tech
    Thanks for the help.
    But the pictures not clear writing and the circuled plug is only 20 pins..
    The steering control plug is 28 pins from the head unit I am installing it is the Toyota 86 touch navigation screen .. so which one of them needs to be grounded? They are 5 steering wheel control wires..
  6. Mudko3
    Mudko3 New Member
    VA
    2014 Prius v wagon
    Sorry the post under that states that the highlighted plug is for a different system, on the bottom left you will see L35 or plug 35 I call it. I cut and grounded wire 23 specifically which gave me my steering wheel controls back for AC/ trip control.
    Now I do not have my volume control because I opted to not buy the module.
    Hopefully that explained it better. Might be different because this car is in the US. Not sure in NZ (assumed cause of name :p)
