Upgrades to Increase Crosswind Resistance
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Huy, Mar 30, 2013.
  1. Huy
    Huy New Member
    I drive 3000 miles every 2 weeks because of my job. I am wondering what type of upgrades people would recommend to increase the crosswind resistance of the car, especially when driving past a big rig.
    I have been told the stiffening the chassis should help? Sway bars, strutt bar? center bar?
    I have also been told upgrading the springs would help as well, but I want to avoid that since it'll lower the car and it won't be acceptable for my uses.
  2. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Is it that bad? what's the speed differential?
    I would think any suspension improvements would help.
  3. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
    I have the same car you have. Depending on the $$$ available, I'd recommend, in this order:
    - the underbody center brace by Rude person's (cures about 70% of the crosswind tug)
    - the front underbody brace by Rude person's (tightens up the front of the car - for example, I don't feel the ICE starting since this brace got bolted on)
    ...the above mods are easiest and least costly, and have a huge impact on crosswind instability - but fellow PChat member Rude person's only makes them in batches when the planets align just right - so you might want to ping him via private message...
    - much better cornering responsiveness: throw on a TRD rear anti-sway bar. Easy mod to bolt on but you'll spend some $$$.
    - effortless and railroad-accurate steering at any speed : try the Cusco front Strut Tower Brace. More $$$, and the most complex piece to put on, because of all the disassembly/reassembly of the plastic stuff under the hood.
    Bullet Salvador likes this.
  4. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    I think it has to do with energy efficient tires that we have, if you have stickier tires you should feel less crosswind jolt.
    I have all the above mentioned mods to our Prius except the Rude person's mid/rear cross brace. I can still feel the car jerk whenever I get hit with a strong crosswind.
  5. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
  6. Toppcat
    Toppcat Member
    223
    69
    Northern California
    Front sway bar upgrade! That the only parts that will push back when one side is lift up or dips down! Or lowering springs and even adjustable coil overs.
