Upgrading 2004 Prius with Navi
Discussion in 'Gen 2 Prius Technical Discussion' started by Zeuser, Dec 6, 2007.
  1. Zeuser
    Zeuser New Member
    I'm really looking at a 2004 Prius these days but it doesn't have the factory navigation. I was wondering how hard it would be to mod it wit ha factory navi. My friend did it with his M3. It's a pretty difficult job but it's doable. It just takes a lot of elbow grease and time *IF* you know how to do it. So... "how" is it done on a Prius?
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    I think your best hopes for NAV with a non-NAV 04 Prius is to get a portable device. Trying to add the OEM system would be cost prohibitive.
  3. Zeuser
    Zeuser New Member
    Really? I would think it's a lot less cost prohibitve considering the Prius already comes with the LCD screen. In other retrofits, like my buddy's M3, you have to change major pieces of the dash just to get that LCD screen in there. since that job is already done on the Prius, I would think it would actually be VERY reasonable in terms of pricing. Oh... and if I wanted a portable navi, I wouldn't be asking for the factory install. Portable navi is out of the question. I already 2 portables anyway and neither is going in the Prius.
  4. firepa63
    1,761
    208
    There are several components required including a computer. Not an easy or inexpensive job.
  5. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    In order to install factory nav, you would have to replace, among other things, the entire dash wiring harness, the MFD screen, you would have to add the nav ECU, you also would need the antenna...... Might almost be cheaper and easier to simply find a different Prius with factory nav....
  6. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    and the aftermarket units totally kick the factory nav's butt.
    _H*
  7. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    nav upgrade
    Skip the factory GPS; as others have said, the aftermarket Garmins, etc, are much better and you can use them in other vehicles (or airplanes). One nifty thing about an add on is that you can have GPS running at the same time as the normal MFD functions, AND, you can program the GPS without having to stop the car. This latter disfunction is one the main gripes Prius owners seem to have for the OEM system.
  8. acdii
    acdii Active Member
    1,124
    131
    This is one of the reasons cars with nav have a lower resale value than non nav. Its cheaper to buy an aftermarket that is easily updated than the builtin ones that are not and dont have as many features. Something to keep in mind the next time your out looking for a new car.
  9. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    Navigation
    I just got my Prius a few weeks ago and my '08 (I think) has navigation capability, but it appears that it is not activated. What is the easiest way to get this navigation feature activated and ready to use?
  10. agile pagile
    agile pagile New Member
    46
    Benicia, Ca
    Navigation
    Why is it that all the complaints about the navigation in the Prius, are from people that didn't get the navigation package. Having the OEM navigation is a wonderful thing because you don't have to worry about removing the unit when you park or hiding it. People have said that the suction cup marks on the windshield are a welcome mat for thieves. With OEM navi there are no worries if you forget or don't have time to hide the unit. As far as resale values for packages having navi being lower than ones without, where is your proof? See, you should have gotten OEM navi in the first place.
  11. aaf709
    3,862
    2022 Prius Prime
    Built in NAV
    Look under the driver's seat; the NAV system (the DVD part) is there. If it isn't there you don't have the NAV system. If you have it, it should work by pressing the MAP button.
  12. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    What makes you think that it has the navigation system?
    How many buttons does your car have on the Multi Function Display bezel? If you have seven (four on the left and three on the right), you have the NAV, otherwise you don't.
