Upgrading 2005 Radio
Discussion in 'Gen 2 Prius Audio and Electronics' started by Xiidaen, May 15, 2012.
  1. Xiidaen
    Xiidaen New Member
    17
    Most of the threads I see in here are for people who know what they're doing -- I'm not one of them. I'm looking for suggestings on purchasing a replacement radio and installation services, either a national chain or someone near Central NJ.
    I've currently got a satallite radio plugged in to the AUX, and it's the "5" model with the navigation system and CD Changer. I'd like to get the following:
    -- apple / ipod support (mini-jack is fine, or more fancy)
    -- use of existing Sirius setup, or it's own capability
    I somehow doubt this is as simple as going to best buy and picking a radio off the shelf and telling them to install it, but I thought I'd check with the experts here first as to the best way to proceed. The aftermarket items on here might work, but I thought it might be better to replace things as opposed to adding to them.
    Any suggestions are much appreciated!
  2. cnschult
    cnschult Active Member
    772
    96
    Michigan
    to just run an ipod with the older prius just you a cassette deck adapter. I've had half a dozen ones over the years and the black ones all gave that hissing noise. recently I picked up a white phillips cassette adapter at sears for only $9, no hiss at all, perfect sound (keep in mind that .mp3 music is of much lesser quality than CD audio .WAV files)
    a cheap and easy solution
