Upgrading Footwell Lights to LED
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Chilcoot, Aug 15, 2019.
  1. Chilcoot
    Chilcoot New Member
    Eagle River, AK
    The last step in my interior LED conversion plan is to upgrade the footwell and glove box lights. The OEM lights seem to be as described in this post about a Prius V retrofit.
    I need better wiring instructions than in that thread. Would someone be so kind as to detail for me how I would wire tiny LED panels like the ones below into my 2016 Prius Four?
    Thanks much!
  2. ChapmanF
    15,643
    This post made me so curious I went and popped one out of my Gen 3, having assumed all along it was already an LED, and it is. What's the point? Just to have a different color LED?
  3. Chilcoot
    Chilcoot New Member
    Eagle River, AK
    Yes, I want to upgrade the appearance of the OEM lamps. In my circumstance, with LED panels like I posted. And yes, they will have a different color.
    For my Gen 4 Prius, I'd appreciate any explicit instructions on how to wire such panels into the existing housing. Thanks much, truly.
  4. ChapmanF
    15,643
    Sorry, I just didn't know what to make of the thread title "upgrading ... to LED" when they already are LED. Not questioning your color change, if that's what you're into.
  5. Hidyho
    Hidyho Senior Member
    2,698
    529
    2018 Prius
    The Multi-Light panel in the image just plugs right in, the prongs are pretty much the same as factory, look inside the plug in opening of the light, if there are prongs there, I should be right.
    #5 Hidyho, Aug 16, 2019
  6. Chilcoot
    Chilcoot New Member
    Eagle River, AK
    Thank you very much, Hidyho. Your post gives me confidence.
    I will post my results when I have them.
  7. Hidyho
    2,698
    529
    2018 Prius
    Found a pic looking into the plug for the light.
