Upgrading headlights to LED
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Katsuranomiya, Aug 6, 2018.
  1. Katsuranomiya
    Katsuranomiya Junior Member
    16
    Ottawa, ON
    Three Touring
    I have a 2012 touring. The right bulb went out. I can figure as much that it's a combination purpose for daytime running light and hi-beam. Popped it out and as expected, sylvania 9005 HB3-U 12v60w halogens.
    I can find 9005 LED online but often the wattage indicated is not an exact match.
    I have two questions:
    - Will any 9005 serve as dual purpose, or does it take a special bulb to behave that way.
    - Is 60w the appropriate capacity, or is there some flexibility there, as typically I would expect LED to consume fewer watts for the equivalent lumens of output, and likewise produce less heat per watt.
