Upgrading to 17" wheels
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Actor with a Prius, Dec 31, 2013.
  1. Yes, didn't notice much mpg loss
    50.0%
  2. No, Looks great, but I get the same mpg as a Hummer
    0 vote(s)
    0.0%
  3. Somewhat, i lost some mpg, but she looks so much better now!
    50.0%
  4. What's mpg? I just put on some rims to make her look sick!
    0 vote(s)
    0.0%
  1. Actor with a Prius
    Actor with a Prius '10 Prius : 50 mpg & '90 Nissan 300ZX TT : 5 mpg
    52
    Miami Beach
    Hello,
    I dont know if this should go here or the Technical forum, so I apologize if its wrong. I just figure people on here already have put 17's on their car as well as probably lowered, etc.
    I want to put on 17's on my 2010 Prius. Almost thinking about lowering it and putting on a body kit as well. Yeah, i'm that guy that hooks up everything lol.
    I dont get amazing mpg in my Prius, maybe due to the tires not being LRR or the fact I drive like an a-hole. Probably the latter. So, I'm not extremely worried about losing some mpg when upgrading. However, I do want to go with as light wheels as my budget allows, as well as some LRR tires.
    I've been searching and cant seem to find what i'm looking for. I wanted to find out:
    1) What is the weight of the stock 15" rims (w/o tires) as well as the stock 17" rims.
    2) What difference would a width of 7" or 7.5" make ?
    3) Does lowering the car (springs) have any effect +\- mpg ?
    4) Assuming the 17" rim is the same weight as the stock 15", wouldn't mpg increase due to added circumference? More distance per rotation at the same weight...
    I've looked at a few wheels online. Seen one I really liked that weighs 18.5 lbs. Not sure how much more that is than the stock 17''s ? I understand from what I read when I first bought my car, that my version IV with 15" wheels and the V with 17" wheels both get the same 50mpg, So I figure those 17's have to weigh around 16-19 lbs each no ?
    Any info would be greatly appreciated. Thanks! Especially pics of your hooked up Prius!
    Thanks!
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Weight isn't a major factor in fuel economy, but the width is. The wider and bigger you go the worse the mpg.
    The 17" wheel Prius may be advertised as getting 50 mpg but that's because EPA rules allow that (based on the lower trims). In reality, it's a ~1.8 mpg hit according to the European version of EPA testing.
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Regarding #4, no. The circumference of the tire should be about the same regardless of rim diameter.
    You WILL lose mpg going from 15 to 17 inch wheels, even if the wheels are the same weight. Why? Because the 17 inch tires typically weigh more than 15 inch tires. More mass further from the center of the wheel makes deceleration and acceleration harder, therefore more power/gas is used.
    SCH-I535
  4. ursle
    ursle Gas miser
    1,049
    192
    NH
    The 17" are going to be 1.5" wider @ the tread, much heavier(tires are 6lbs more, lot's more metal in the rim, true, lot's of $ will lighten the load ) and in reality 4-5mpg of loss, but, pretty;) ;)
  5. Actor with a Prius
    52
    Miami Beach
    Well, the wheels that I found are 7" wide, just like stock. they weigh 18.5 lbs. I don't know how much the stock 15's or 17's weigh. I do think it drastically changes the look of the car. a couple mpg isnt too bad. Since I average 40mpg anyway.
  6. oalvarez
    oalvarez Junior Member
    Los Angeles
    Do any of you know if the 17" wheels that came on 2010-2013 Level Five cars fit the 2014 models? I would think "yes" but just wanting to make sure before I set out to find a used pair. I like those wheels (had them on our 2010), they improve the car's look in my eyes, and to be honest, I care very little about the added weight of the wheels or the fact that the car has a sunroof. At the end of the day, the manufacturer puts these wheels on the Level Five cars and work adequately, that and I personally don't buy into the weight of the sunroof being a big detractor. Ymmv. ;)
  7. 32kcolors
    5,683
    953
    124
    Redondo Beach, CA
    It's the combined weight of 17" wheels, leather and solar roof that caused Toyota to delete the SR option in order not to have two separate EPA categories for fuel economy, supposedly for marketing purposes as it's easier to advertise the same 50 mpg rating for all the trims. They didn't actually care about the weight itself and some members here have fitted their Solar Roof Prius with OEM 17s with no problems.
    Yes, the OEM 17s will fit the 2014. They're the same wheels and cars.
    oalvarez likes this.
  8. oalvarez
    Los Angeles
    Thank you!
  9. oalvarez
    Los Angeles
    One more question if i may, are the lugs from the Level Four 15" wheels the same as those for the Level Five 17" wheels? I'd assume yes, but always a chance for them to be different lengths.
    Thanks in advance,
  10. xliderider
    7,869
    3,116
    Honolulu, HI
    The lugnuts will be fine for the 17s.
  11. oalvarez
    Los Angeles
    just back from picking up the Level Five wheels and having them installed at the local tire shop. went with Hankook Ventus V12 Evos...decent dry/wet tire, relatively quiet as per Car & Driver...probably more tire than i need, frankly. regardless, loving the "new look" of the car and how it feels on the road. really happy/lucky to have found the wheels on Craigslist, along with having sold the stock rims/tires that came on the car.
    much better. ;)
  12. Actor with a Prius
    52
    Miami Beach
    What are the weights of the stock 15's as well as the upgraded 17" V wheels ?
    Just found a couple wheels I like. Both sets in 17x7. One is 18.5 lbs, the other is 16 lbs. Now gotta also see about LRR low profile tires.
    Just wondering how light/heavy the 15/17's from toyota are.
