Upgrading to 17in wheels?
Discussion in 'Prime Accessories and Modifications' started by Ajay21, May 4, 2017.
  1. Ajay21
    Ajay21 New Member
    16
    25
    Los Angeles
    Thinking of upgrading my wheels to this BBS forged rims...what do you guys think?...14.3lbs lighter than stock..
    quadturboprime likes this.
  2. quadturboprime
    quadturboprime Junior Member
    Los Angeles
    You should do it!!! Is it really that much lighter though??
  3. Tideland Prius
    16,155
    14.8lbs lighter than the stock 17" or the stock 15"?
    That looks like a nice replacement (reminds me of the Wedsports...forgot the model... that was available on the Gen 2 Prius)
  4. a_gray_prius
    2,927
    782
    IL
    Those RFs look a bit like the stock wheels Evo Xes came with. I have RAYS Eco drives on our Gen2 Touring, which are quite a bit lighter than stock, but they don't make nearly as much of a difference as tire choice. Some of the very low UTQG (e.g. very high grip) tires I have mounted on them have decreased MPG noticeably.
  5. martydallas
    martydallas Member
    106
    84
    Dallas, tx
    stock is 15" right? and if going to the 17" what does it do to the MPG and EV reporting on the car?
  6. JoePriusPrime
    JoePriusPrime Member
    46
    35
    Denver, CO
    Hey AJ,
    I'm planning on doing the same thing upgrading to BBS SR 17s. Only cost $255 per wheel because it's not forged. The weight listed is 20lbs per wheel. Anybody know the stock OEM 15in wheel weight?
  7. a_gray_prius
    2,927
    782
    IL
    The weight of the Gen2 Prius 15"wheels was about 14lb. I expect the prime wheels to be about the same.
  8. Mendel Leisk
    38,726
    #8 Mendel Leisk, May 11, 2017
  9. JoePriusPrime
    46
    35
    Denver, CO
  10. Mendel Leisk
    38,726
    More than just weight I think.
  11. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    Definitely. Larger rims puts more rotational mass concentrated at the outer diameter of the wheel,which makes accelerating and slowing the wheel down more difficult than a wheel of similar weight that has the weight more evenly distributed toward the center. 17 inch tires typically weigh more than 15 inch tires, so yes, a lighter weight rim helps, but a 15 inch wheel/tire combo will always get better mpg than a 17 inch wheel/tire combo of equal combined weight.
