Uphill or downhill?
Discussion in 'Gen 3 Prius Fuel Economy' started by lamontcranston, Aug 24, 2009.
  1. lamontcranston
    lamontcranston Umbra Tenet
    212
    17
    Southern California
    Simple question...
    Assume you've got a big hill to climb, and it's the same distance uphill as downhill ...
    Is it better for fuel economy to accelerate hard to get to the top of the hill, then be able to glide for a longer time on the downhill?
    or
    Is it better for fuel economy to let the speed slip on the uphill and use the engine to accelerate back to speed on the downhill?
    I've tried both and I can't definitively tell which works better.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Neither. Let the speed slip on the uphill side, and let gravity accelerate you on the downhill.
    Tom
  3. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    Good Advise. I generally drive my G3, IV normally. I stay with the flow going up, not accelerating, at the crest of the hill I may regain any speed that was "bled" off going up, but if it is a long downhill, I find the "sweet spot" and let her coast. If the speed picks up too much, I retard it with the "B" setting, otherwise, I let her run free. As long as you are not driving 75-80 mph, I find I can achieve about 53 mpg on the Interstate, even in the mountains (where we live).
    Good Luck
  4. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    I would say if possible pick up a little excess speed prior to the hill, then let the speed decay as you climb it, the objective being to stay out of the power portion of the HSI. I would coast as much as possible on the downhill, use regen braking if necessary, but stay out of B if possible, B's function is to waste energy and I would want to recover, not waste if possible. Be cautious of safety of course, use B if needed for safety.
  5. lamontcranston
    212
    17
    Southern California
    That makes a lot of sense! Thanks!
