Upper dash board plastic cap(s)
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by z80, Sep 23, 2017.
  1. z80
    z80 Junior Member
    23
    2014 Prius c
    I
    Hello!
    There is a hole for blowing air on car's windshield in upper part of dash board. On the left of that ventilation hole there is a plastic "cap" (please, see attached image). But I didn't ever care if there is the same cap on the right. And today I noticed that there is no the same thing on the right. Should it be there? I also can't find appropriate part number. I would be very much obliged for any information! Thank you!
    49,507
    welcome!
    that might be a sensor of some sort? if no one knows, ask your local parts dept.
  3. Mendel Leisk
    38,735
    Sunlight sensor?
    Sean Nelson likes this.
  4. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I believe that is what's called the "sun load" sensor for the HVAC system. Yes, there is only one of them and its purpose is to adjust the HVAC output based on whether the sun is shining in through the windows. You need more A/C to maintain the set temperature if the system has to deal with that thermonuclear energy bombardment.
  5. Mendel Leisk
    38,735
    Dash brightness too I think.
