Upper Glovebox Light - What Size Bulb & How to change it?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Sunfire4jc, Dec 3, 2007.
  1. Sunfire4jc
    Sunfire4jc New Member
    32
    Hello All,
    I was wondering if any of you have replaced the glovebox light and if you can give me any hint on
    1. How to get to the bulb without removing too many parts
    2. What size the is the bulb - I hate the ugly amber color, i want to replace it with a white bulb.
    There was a knowledge base article, but the link is broken now. Any help would be greatly appreciated. Thanks!
    Regards,
    Stephen
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    I'm pretty sure there is no light for the upper box...only the lower one.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Maybe if you put a really bright LED in the bottom box...
    As Evan says, there is no light in the upper box.
    Tom
  4. Sunfire4jc
    32
    Haha, I meant the upper part of the lower glovebox compartment. My bad
  5. efusco
    19,891
    1,192
    Nixa, MO
    It's an LED bulb and it shouldn't burn out...are you still under warranty?
    I'll have to leave it to someone else to tell you what bulb you need to replace it with.
  6. jbrasher
    jbrasher Junior Member
    OC, Ca
    And the reason it stays on all the time is because s switch would be more likely to break than the blub burning out?:confused:
  7. efusco
    19,891
    1,192
    Nixa, MO
    yep and probably the LED bulb is cheaper than a incandescent + switch and the LED uses less power.
