URGENT About to buy 2010 Prius IV with 73k miles original owner, Advice on problems and price?
Discussion in 'Gen 3 Prius Main Forum' started by TheGrayt1, Oct 18, 2020.
  1. TheGrayt1
    TheGrayt1 Junior Member
    48
    Plano, TX
    Hey all,
    I have been in the market for a third gen Prius for awhile de to starting anew job in Dallas that is about 35 miles away from me. I found a nice 2010 original owner Prius that has pretty much every option except nav and the solar sunroof package. Always serviced at the Toyota dealer locally and all recalls taken care of. Clean title and never wrecked.
    My questions are as follows
    1. I know this is the first model year of the new gen and should I be concerned about bugs not being worked out? When I look this model up on car complaints there are a ton of reports of excessive oil consumption for this year model. Is this a widespread problem? I asked the owner and he said it does not use any oil, so was this a limited issue to some cars? Are there any other big problems with this year model? Should I look for a newer one and avoid this one like the plague?
    2. The car is getting close to 50 mpg if you drive it lightly. Does this mean the hybrid battery is still good? How long are these gen batts generally lasting if garage kept?
    3. I am getting it for $8,000 and it is super clean with a few minor door dings like any car but above average for sure. Is that a good deal?
    Thanks in advance!
  2. hill
    8,750
    It's a matter of "odds". Most Prius will easily run for over 150k w/ no issues. Many will do over 200k and beyond. But no one can say w/ certainty. It's like weather prediction. So- there's maybe a 99% chance your new ride will easily run for over 150k ... & maybe an 89% chance it will get to 200k miles & beyond, problem free. Either way - it's a guess.
  3. Grit
    Grit Senior Member
    6,573
    4,225
    Wilkes Land
    No test drive, no buy.
    Triparadox likes this.
  4. TheGrayt1
    48
    Plano, TX
    I am test driving it here in 4 hours but the owner has been very honest and everything he has said lines up with the toyota service records I pulled online with the vin number.
  5. TheGrayt1
    48
    Plano, TX
    About to head out to go loo at it, any last comments? What do you think of the price? Any comments on oil consumption?
  6. bisco
    51,646
    you should be fine, but keep in mind the battery warranty is up and will probably need to be replaced during your ownership.
    also, you will need to clean the egr circuit and add an oil catch can to prevent a blown head gasket.
    if the price meets kbb.com, that's all you need to know.
    all the best!(y)
    SFO likes this.
  7. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I have a 2010 with 100,000 miles that runs like new. Mine uses some oil, maybe a quart in 4-5,000 miles so I check it regularly. I think you are getting a fair deal.
    Battery is probably fine for at least another few years but you can check on battery health by getting an OBDII bluetooth enabled adapter and running the Dr. Prius App. I'd recommend that for future monitoring even if you have already decided to buy it.
    You will read in PriusChat lot about EGR issues in the gen 3 but it is way to early to consider cleaning it in your case. I'd consider it when spark plugs are due at 120,000 miles.
    #7 royrose, Oct 18, 2020
  8. orenji
    orenji Senior Member
    5,887
    3,488
    Sounds like a great deal. I have no oil issues and I change my oil every 5k miles. Don’t go 10k miles as that’s too long. You should also consider using thicker oil than the 0W-20 as that is probably one of the main reasons for Prius to burn oil. I have been using 0W-40 Mobil 1 for about 50k miles. No issues and no burning oil. Like others have said get the EGR cleaned and install a Catch Can. This is extremely important for the future health of your motor. Other than that, make sure all the fluids get changed per Toyota Recommendations and have the Tranny fluid drained and filled every 60k miles. This is not noted by Toyota as they say the fluid is lifetime. But nothing is lifetime. For $100 at the dealer it’s cheap insurance. Hope you enjoy your new car!
  9. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
  10. Leadfoot J. McCoalroller
    8,036
    7,518
    Pennsylvania
    2018 Prius c
    Oil consumption has been a concern with other 2010s.
    At fully ten years of age, most of the good days are past for this one.
    That does not mean it isn't a good car or a good value, just keep your expectations in line and you'll be fine!
  11. orenji
    5,887
    3,488
    It’s still young at 70k miles. It’s got lots of life left in it in especially if all the precautions I mentioned above are taken.
  12. orenji
    5,887
    3,488
    Toyota oil recommendation for several countries for the Gen3 motor is 40 weight and up to 50 weight oil. Perfectly fine to use in the Gen 3. Plus Mobil 1 oil tends to be on the lighter side of these numbers.
  13. PriusTransduced
    PriusTransduced New Member
    I brought a 2011 Prius 4 new. It now has almost 300,000 miles. It has been one of the best cars I have ever owned. I haven't had any issues with oil consumption, although it is frequently reported. The only issue I have had from the start is that it burns through head lights. I found when I changed the type of bulb, they last longer. I replaced the 12V battery at about 265,000 and it was about $225. Hope it works out for you.
    Merkey, SFO and orenji like this.
  14. TheGrayt1
    48
    Plano, TX
    So I ended up buying it and got it for $7750 even bc a wheel cover was missing lol. i checked the oil and it was 3k miles in and was full so do not think it burns oil. Hybrid battery seems perfect and I got 52mpg on the way home in eco mode.
    Can someone provide a step by step on egr valve cleaning? Will that protect the ehad gasket? I did not read about head gasket problems but I do not think mine has it as it is a southern car and garage kept.
    Last thing, the engine bay was a bit dirty just due to being parked under a tree for the last few months after it got moved out of the garage. I was nervous to spray degreaser and light pressure water on the engine with all the electronics. What is the proper and safe way to wash a prius engine?
    #14 TheGrayt1, Oct 18, 2020
    Triparadox, dig4dirt, orenji and 3 others like this.
  15. bisco
    51,646
    congrats!
    see @NutzAboutBolts youtube for egr cleaning and all things gen 3 prius.
    do not powerwash the engine bay, too many electricals. i've never cleaned mine, but someone will chime in.
    all the best!(y)
    Triparadox and NutzAboutBolts like this.
  16. royrose
    1,389
    953
    Foot of Pikes Peak
    Congrats on your purchase. it looks great.
    It's the EGR cooler that gets especially clogged.
    Here is a link to Nutz About Boltz videos about maintenance of the gen 3. The EGR cooler video is #17.
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    And here is a good discussion of the process. note that the poster cleaned his at 115,000 miles and it wasn't fully clogged, so I stick with my suggestion of doing it when you change plugs at 120,000. For now, enjoy. Others may disagree and have other recommendations.
    EGR & Intake Manifold Clean Results | PriusChat
    #16 royrose, Oct 18, 2020
  17. orenji
    5,887
    3,488
    Just take a wet rag and wipe down the engine. The plastic silver cover pops off and you can wash that off the engine. The EGR cleaning is not that simple. So if you’re not much of a mechanic you may want to find someone. I would do it around 90k miles IMO waiting till 120K miles is too long.
  18. slalomboi
    slalomboi Junior Member
    Seattle
    My 2010 Prius II at 292,000+ miles is using about 1quart oil/750 miles = 2 fill-ups. A friend has well over 300k on his. We both just add oil and keep driving.
  19. Attila Fekete
    164
    59
    Budapest, Hungary
    Which doesn’t mean it’s recommended everywhere. I assume where they recommends the w50 is not Canada. In Hungary - temperature is mostly between 5 - 95 Fahrenheit during the year - the recommended oil is 0w-20. 0w-30 can be used exceptional and had to be replaced with 0w-20 at the next oil change.
    So I don’t see reason using 0w-40.
    The numbers you can see in the linked PDFs.
    In my opinion you have to know what you do when you use oil that is not the recommended.
    Using all the time in highway or in traffic jam is quite different usage pattern.
  20. Evoking
    Evoking Junior Member
    91
    16
    Pomona
    I just got my 2010 prius with 83k on it and I never thought about adding a catch can to it is it really that recommended
